Drain Field In-line Chlorinator - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-27-2013, 01:56 PM   #1
drain field in-line chlorinator
I have occasional odor from what I think is a dry well. It's a n 1890 house.
There are no wet spots but the area's frequently moist from run-off as it's a low area. A contractor said that since the problem doesn't seem very bad an in-line tablet type chlorinator installed after the septic tank (which is new) would get rid of the odor. Make sense? Thanks.
kentannenbaum is offline   Reply With Quote
Old 04-27-2013, 02:39 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 996
Better off with an enzyme injector.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
oh'mike (04-27-2013)
Old 04-27-2013, 03:05 PM   #3
Obviously, you know and I don't. Checked out the Viking enzyme injector, seems total overkill. This is for a house with zero odor issues near the house.
The occasional odor is 75ft away near what is probably a dry well; the house is old and we just don't know for sure. Anyway, the question is whether an in-line chlorinator will work for minor odors. Again, thanks.
Old 04-27-2013, 07:40 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 996
No it wont. is that clear enough. not gonna bother with an explanation obviously with all that reading you should know what causes the smells. lets see lets install a chlorination injecting system in to a septic system Humm? unless you have an aerobic system ,then it would already have one..the contractor who told you that is way off base very bad advise. not to mention that the smell may not be related to the septic run off.
Old 04-27-2013, 07:45 PM   #5
Thanks!
Old 04-27-2013, 07:56 PM   #6
DIY staff
Rewards Points: 7,174
The chlorine will kill the bacteria that makes a septic system work-----for the best advice call in a septic system company----either the person you are dealing with has--limited knowledge---or you misunderstood him.
Old 04-27-2013, 08:38 PM   #7
Got it, will do.
Zep Drain Care for larger drains? Ultrarunner2017 Plumbing 13 01-10-2013 09:51 AM
Drain line for toilet PatSea Plumbing 6 06-11-2011 10:53 PM
Tree root & drain line - delima ? CZSteve Landscaping & Lawn Care 1 02-21-2011 10:28 AM
Water heater drain pan line Bigmike33 Plumbing 1 09-22-2010 08:29 PM
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 07:09 PM
