Drain Configuration Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-26-2012, 10:15 PM   #1
Rewards Points: 150
Drain Stack Configuration Question
Hi,
I am about to get started on my plumbing for the basement project. This will begin with plumbing the drains for the dishwasher/sink with disposal, washer, and vanity/lav drain.
Please reference my novice sketch and let me know your opinions.
(What I am looking for is wether the "stack" order I have drawn is adequate)
Thank you in advance.
oodssoo is offline   Reply With Quote
Old 12-27-2012, 10:41 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
If those are all dumping into the same vertical piping, what you have there is called a wet vent. I'm not sure if that's allowed in your area, but it sure as heck isn't allowed where I live. (UPC Based code)
Then again, your drawing is somewhat incomplete... hard to tell exactly what you plan on doing.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
oodssoo (12-27-2012)
Old 12-27-2012, 10:52 AM   #3
Rewards Points: 2,512
Thats a major over a minor. The washing machine pumps alot of water fast. Dont install a major over a minor.
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
Old 12-27-2012, 11:15 AM   #4
Rewards Points: 150
Thank you, Hammerlane!
So, let me get what you are saying correctly... Are you suggesting that I have the following setup?
(from top down)
A: Vanity/Lav drain (minor)
B: Kitchen sink/dishwasher drain (major)
C: Washer drain (major)
Please advise.
Ps. Alan, I plan to use Air Admittance Valve (AAV) to vent my kitchen and vent my washer and vanity out the air vent pipe (which I believe is 2").
Old 12-27-2012, 11:33 AM   #5
Rewards Points: 660
I think you need to clarify: are these all dumping into one main stack drain on the same floor?
If so, what distances are each of these from the main stack? Why can't you re-vent to avoid wet venting?
Give us a little bit more of an idea of what is going on.
B
Beepster is offline   Reply With Quote
Center Drain Washine Machine Outlet Box Question Please Help!! joshua.easter Plumbing 9 07-23-2012 09:46 PM
Utility sink drain pipe question jabergess Plumbing 3 05-06-2011 09:01 AM
Replacing putty in shower drain, question about drain construction scottyv81 Plumbing 4 03-28-2011 08:43 PM
Venting a sink drain pump question gellswor Plumbing 0 11-20-2010 08:57 AM
Existing French Drain Question chrisswany Landscaping & Lawn Care 4 08-17-2010 11:55 AM
