-   -   Drain Configuration Question (http://www.diychatroom.com/f7/drain-configuration-question-167459/)
oodssoo 12-26-2012 09:15 PM
Drain Stack Configuration Question
1 Attachment(s)
Hi,
I am about to get started on my plumbing for the basement project. This will begin with plumbing the drains for the dishwasher/sink with disposal, washer, and vanity/lav drain.
Please reference my novice sketch and let me know your opinions.
(What I am looking for is wether the "stack" order I have drawn is adequate)
Thank you in advance.
Alan 12-27-2012 09:41 AM
If those are all dumping into the same vertical piping, what you have there is called a wet vent. I'm not sure if that's allowed in your area, but it sure as heck isn't allowed where I live. (UPC Based code)
Then again, your drawing is somewhat incomplete... hard to tell exactly what you plan on doing.
hammerlane 12-27-2012 09:52 AM
Thats a major over a minor. The washing machine pumps alot of water fast. Dont install a major over a minor.
oodssoo 12-27-2012 10:15 AM
Thank you, Hammerlane!
So, let me get what you are saying correctly... Are you suggesting that I have the following setup?
(from top down)
A: Vanity/Lav drain (minor)
B: Kitchen sink/dishwasher drain (major)
C: Washer drain (major)
Please advise.
Ps. Alan, I plan to use Air Admittance Valve (AAV) to vent my kitchen and vent my washer and vanity out the air vent pipe (which I believe is 2").
Beepster 12-27-2012 10:33 AM
I think you need to clarify: are these all dumping into one main stack drain on the same floor?
If so, what distances are each of these from the main stack? Why can't you re-vent to avoid wet venting?
Give us a little bit more of an idea of what is going on.
B
