Drain In A Cold Zone? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-29-2009, 03:19 PM   #1
drain in a cold zone?
can a drain and trap from a bathtub enter a cold zone, behind insulation and the vapour barrier and then return into the warm zone in the house?
boddah is offline   Reply With Quote
Old 06-29-2009, 03:40 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
A drain line can, but a trap may freeze.
Mike
Mike Swearingen is offline   Reply With Quote
Old 06-29-2009, 03:44 PM   #3
if it freezes will it crack the pipe? it should have enough room for expansion right? and the next shower will melt the ice anyway. is this a safe idea, cause i have no other options?
Old 06-29-2009, 08:00 PM   #4
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
If the trap freezes then it CAN break. Will it break? Who knows but you are creating conditions that can cause it to happen. As far as the next shower thawing the ice clog.....how high do you imagine the water in the tub will be before that clog melts? My bet is mid calf.
JDC is offline   Reply With Quote
Old 07-04-2009, 08:47 PM   #5
it will expand alright
you will have to do something to keep it from freezing. why cant it be insulated? what is below it. how do you plan to seal the hole in insulation that you made. is there access to the bottom of drain? if so you will need to figure out how to hang insulation................... there is another option here. you can let the hot water run all winter plus spring until the frost come out of the ground. breid
breid is offline   Reply With Quote
Old 07-04-2009, 09:53 PM   #6
Where are you located?
What type of pipe - PVC - yes it will crack or burst the seal/joint where it is glued together
need some help sorting out my new heating zone please wombosi Plumbing 3 04-23-2009 04:54 PM
help with third heat zone i just put in... wombosi HVAC 6 04-21-2009 12:02 PM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
