Drain Cleaning - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-28-2008, 09:13 AM   #1
Joe F's Avatar
Rewards Points: 294
Drain cleaning
I recently heard that dumping bleach into your drain once a month or so will keep it clean. Any truth to that? My house is almost 50 years old, drains work fine and I'd like it to stay that way.
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 02-28-2008, 09:28 AM   #2
If you're considering a monthly preventative type of treatment, you might want to take a look at some of the enzymatic additives available. They come in powdered and liquid forms and are designed at keeping drains clean, not unclogging clogged or very slow ones. Plus, they are much better for the environment.
End Grain is offline   Reply With Quote
Old 02-28-2008, 09:35 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
I never use bleach (on a septic system) or caustic drain cleaners for drain cleaning or maintenance.
As End Grain suggested, go with a good enzyme-based drain cleaner only such as DrainCare. It will not harm your fixtures or drain pipes, it's better for the environment, and will eat out all organic gunk (hair, grease, oils, soap scum, etc.), usually overnight.
You just run a little warm water down the drain, pour in the enzyme-based drain cleaner, let it eat overnight, and then flush it down with very hot water. I start that flushing with a kettle of boiling water, followed by the hot water only.
Sometimes, if there is a bad clog, you have to do it more than once, but it works like a charm for sluggish and clogged drains.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 02-28-2008, 09:47 AM   #4
Learning by Doing
Leah Frances's Avatar
Second on the kettle of boiling water! I do this around once a month - I like the price and it keeps my shower drain running clean.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 02-28-2008, 02:00 PM   #5
Joe F's Avatar
Rewards Points: 294
Thanks everyone.
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 03:15 AM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 03:42 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-22-2006 11:13 PM
