Drain In Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-04-2012, 04:00 PM   #1
Rewards Points: 264
Drain in basement
I want to add a bathroom to my basement, but I have a problem. My 4" drain, instead of existing through the basement floor, exists through the wall, about 4 inches off the ground.
Any idea how to correct this problem, without a macerating toilet? I'm thinking I might need to excavate the outside of the wall, extend the pipe to floor level, and then connect my toilet.
Any other ideas?
tibberous is offline   Reply With Quote
Old 06-04-2012, 04:41 PM   #2
MarginallyQualified
Rewards Points: 2,464
Mine used to do the same thing.
Any idea how...
I'm thinking I might need to excavate...
Yep; you're on to the solution all right
You just have to dig into the problem a little more.
Specifically... you need to find where the waste pipe (outside of the house) is low enough to connect to and still give you enough pitch. Then you dig a trench between the two points.
Flooring over basement floor drain BlueBSH Plumbing 8 09-30-2011 09:27 AM
Old Basement Sink Drain - Clay? maybere Plumbing 7 09-27-2011 11:49 AM
Basement vapor barrier over mirror drain eubarch Plumbing 0 09-27-2011 09:57 AM
Backed up basement floor drain billvasko Plumbing 2 02-06-2008 01:09 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
