Old 03-22-2009, 06:52 AM   #1
Drain Backups
Just had a bathroom renovation with new sink and toilet installed. When water goes down sink drain, the toilet and shower drain back up. When toilet is flushed water backs up and takes a while to go down. What could the cause(s) be?
insink
insink is offline   Reply With Quote
Old 03-22-2009, 07:59 AM   #2
JDC
Plumbing Contractor
JDC's Avatar
Drain Backups
You have a clog that needs to be augered out
JDC is offline   Reply With Quote
Old 03-23-2009, 12:59 AM   #3
Drain Backups
You do not say if the plumbing was already installed and you only installed
the sink and the toilet. Let us assume the plumbing was there.
The cause is that right after the sink or the toilet or the shower, there is
a stoppage and it needs to be cleaned. If other places are plugged-up too, then the main line is plugged-up. The other reason is the vent pipes
going to the roof.May be they are plugged-up too.
Gabriel24 is offline   Reply With Quote
Frozen Garage Floor Drain Dragon General Discussion 8 01-25-2009 07:07 AM
Condensor drain Captflx HVAC 6 08-17-2008 11:19 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
