Is This A Drain? (above Water Softner Loop) - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-21-2012, 02:35 PM   #1
Is this a drain? (above water softner loop)
I want to add a water softener and don't want to make assumptions. Is this a drain that I can use for the softener's backwash? Thanks in advance for the help.
Link to image
RobHydell is offline   Reply With Quote
Old 10-21-2012, 03:07 PM   #2
Water Treatment
Rewards Points: 900
I would find out who the plumber that did the work on the house when it was built and find out from them as to why they did the y just inside the wall.
Akpsdvan is offline   Reply With Quote
Old 10-21-2012, 03:24 PM   #3
Rewards Points: 14,026
Looks more like a funky clean out then a drain, very strange set up.
Is that PVC supply lines?
Old 10-21-2012, 03:43 PM   #4
Thanks for responding. Yes the bottom two are supply lines. I have PVC running out of one through 4 big blue water filters and then back.
If it's a clean out could I still use it for the water softener backwash?
Old 10-21-2012, 03:53 PM   #5
Hold in there for some real plumbers to respond.
Old 10-21-2012, 09:27 PM   #6
Hard to tell for sure if the cap on that line is threaded or not, too much white in the pic. Nevertheless a cleanout cannot be used as a drain. Don't you have a floor drain somewhere nearby that you could drain the softener to? Laundry tub/sink?
VIPlumber is offline   Reply With Quote
Old 10-22-2012, 10:02 AM   #7
The cap is NOT threaded. Unfortunately this is in my garage and no floor drain is present. Also I am the third owner of the house and no blueprints were given.
If the cap is not threaded does that mean it's a drain or a cleanout? Is there a way I can tell the difference if I take the cap off?
Old 10-22-2012, 11:08 AM   #8
Water Treatment
Rewards Points: 900
There should be a builder of record for your place.
That builder would have a record as to the plumber for the build.
That is the only real way of finding out the true meaning of the part in question.
The Following User Says Thank You to Akpsdvan For This Useful Post:
RobHydell (10-22-2012)
Old 10-22-2012, 12:21 PM   #9
Thanks for all the advice. I called the clerk of courts and at least have the blueprints (and the developers phone number). Hopefully they will get back to me with the plumbing blue prints.
Thanks again for the help.
Tags
drain water softener
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Basement drain pipe "pit" ground water fix. alecmcmahon General DIY Discussions 13 12-01-2010 05:42 AM
Drain Water Heat Recovery Devices - Thoughts? Educator Plumbing 21 04-12-2008 07:29 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 03:28 PM
