Draft From My Basement Floor Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-12-2010, 03:47 PM   #1
Draft from my basement floor drain?
does anyone have any idea what could cause this? is it normal under any circumstance?
thanks!
baby12121 is offline   Reply With Quote
Old 02-12-2010, 07:24 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
If you are getting a draft from the floor drain, then there is either A ) no p-trap, or B ) p-trap is dried up due to no trap primer.
Look inside with a flashlight to see if you see any standing water. If not, try dumping some water into it, (a quart or so) then look inside with a flashlight again to see if the water is staying. If it's not, then there is no trap, and you just have an open pipe to the air.
Do you know if it drains to the sewer, or just to storm drainage? What is the floor drain used for?
Journeyman Plumber
Old 02-12-2010, 08:52 PM   #3
i just discovered the draft is synonymous with the furnace coming on...there is a pipe which flows into it for the ac condensation to dran. sounds like this is it??
Old 02-13-2010, 01:00 AM   #4
If air is coming out of the drain when the furnace is on then the furnace is pulling it from the floor drain. first do as the other posted said and see if it has a trap, If it does have a trap check to make sure it has enough water in it.
plumber Jim is offline   Reply With Quote
Old 02-13-2010, 03:47 PM   #5
Rewards Points: 346
Plumber Jim, that was my first thought. But the op said "there is a pipe which flows into it for the ac condensation to drain". Since the evaporator is in a pressurized space when the fan is on, it is likely to get a draft from the condensation drain. It doesn't sound like a problem, and if it is, I would not know how to fix it. Putting a valve on the condensation line would be risky because forgetting to open it could cause some real problems.
Rege
RegeSullivan is offline   Reply With Quote
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 09:49 AM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
Major draft from outside detected in basement - how to fix? mwehnes Building & Construction 7 05-08-2007 09:07 AM
