Downsizing Radiator - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-14-2008, 08:10 AM   #1
downsizing radiator
While I am renovating my kitchen I would like to downsize the huge radiator I currently have (53x22x9). I have a smaller radiator (24x19x5) that I am not using and would like use in the kitchen in addition to an electric underfloor heating mat. The larger radiator has a 1 3/4" pipe feeding the it while the smaller radiator has a 1'' pipe feeding it. Does this impose any concerns with how this will impact the system as a whole? The kitchen is on the main floor of a two story house, and the boiler is down in the basement.
aak3 is offline   Reply With Quote
Old 02-14-2008, 04:14 PM   #2
Send a message via AIM to Marlin
Is this hot water or steam? I assume it is a two pipe system as well?
You can downsize your radiator, and downsize the pipes to make it work. You obviously won't have as much heat though.
Marlin is offline   Reply With Quote
HELP! poor daugthers radiator question fauer Automotive Repairs 6 03-16-2008 04:25 AM
Hot Water System -- Cold Radiator formarley HVAC 4 03-04-2008 07:09 AM
Radiator Tune Up goes WELL! How I did it. Leah Frances HVAC 3 01-31-2008 09:20 PM
Radiator leak nonamemark Plumbing 4 11-16-2007 11:50 AM
Plastic caps /wheel heads on radiator PianoMan Plumbing 1 10-18-2005 07:25 PM
