Double Sinks Continually Back Up - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-08-2012, 10:59 PM   #1
double sinks continually back up
Why do my double kitchen sinks continually back up and into my dishwasher
Debbiem86 is offline   Reply With Quote
Old 11-08-2012, 11:02 PM   #2
Rewards Points: 14,014
Have you ever removed the traps under the sink to see if there plugged up?
While the traps are out you need to snake the drain line.
If the water can not get down the drain it has to go someplace.
Old 11-08-2012, 11:31 PM   #3
the dishwasher drain line probably doesn't have a loop up high under the cabinet. post a picture of what is under the sink
Old 11-09-2012, 07:05 AM   #4
http://www.structuretech1.com/2010/07/dishwasher-drain/
Sump pump back up DennyF Plumbing 4 02-17-2012 01:58 PM
double pole breaker + outlets / x10 BlueBSH Electrical 0 09-09-2010 12:44 PM
Need help making a 'back band' around window/door casing. RickDel Carpentry 3 07-15-2010 03:13 PM
How would I fix/re-do my sink's drain <leaking> piping? joeyboy Plumbing 17 12-18-2007 05:23 PM
feed back voltage when using double breaker sluggermike Electrical 59 09-20-2007 02:37 PM
