Double Sink Gurgles! - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-22-2008, 10:39 PM   #1
double sink gurgles!
I recently replaced my single sink vanity with a double sink vanity. The P trap is in the center and now when you run one sink you can heat gurgling noises from the other one. Never had a double sink before, is this normal?
Thanks,
Ben
Bcoleman6 is offline   Reply With Quote
Old 02-23-2008, 12:29 AM   #2
Yes, you're hearing the sound of water slapping over and back and then down the pipe above the P-trap because the sound reverberates from the idle drain.
End Grain is offline   Reply With Quote
Old 02-23-2008, 01:38 PM   #3
Is the sink vented?
redline is offline   Reply With Quote
Old 02-23-2008, 04:44 PM   #4
Knucklez's Avatar
Rewards Points: 930
if it is significant gurgling, then the next item to check is the vent. you should have a vent right near by going to outside world free of obstructions.
Knucklez is offline   Reply With Quote
Old 02-24-2008, 10:49 PM   #5
Yep the sink is vented. The gurgling isn't to bad more of an annoyance. I was just hoping there was an easy fix.
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 08:07 AM
double sink drain piping sockeye Plumbing 7 11-18-2007 02:23 PM
Single Sink To Double Sink 39centstamp Plumbing 4 06-24-2007 11:27 AM
Need Help with double bath sink trap after remodel cmontel Plumbing 13 12-03-2006 07:06 PM
Double sink drainage installation JeffBPaarsa Plumbing 2 11-23-2006 10:08 AM
