-   -   double sink gurgles! (http://www.diychatroom.com/f7/double-sink-gurgles-17495/)
Bcoleman6 02-22-2008 09:39 PM
I recently replaced my single sink vanity with a double sink vanity. The P trap is in the center and now when you run one sink you can heat gurgling noises from the other one. Never had a double sink before, is this normal?
Thanks,
Ben
End Grain 02-22-2008 11:29 PM
Yes, you're hearing the sound of water slapping over and back and then down the pipe above the P-trap because the sound reverberates from the idle drain.
redline 02-23-2008 12:38 PM
Is the sink vented?
Knucklez 02-23-2008 03:44 PM
4 Attachment(s)
if it is significant gurgling, then the next item to check is the vent. you should have a vent right near by going to outside world free of obstructions.
Bcoleman6 02-24-2008 09:49 PM
Yep the sink is vented. The gurgling isn't to bad more of an annoyance. I was just hoping there was an easy fix.
