Double Sink Drain - P-Trap Layout? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-27-2013, 07:30 AM   #1
Double Sink Drain - P-Trap layout?
The sink, without the Garbage Disposal, never drained properly. Does it need to be higher the P-Trap outgoing pipe? Any suggestions?????
madmaxltd is offline   Reply With Quote
Old 05-27-2013, 08:18 PM   #2
Rewards Points: 582
1 st I like to see seperate traps....how about a vent ..is it even vented ..is it pvc all the way to main ...pictures would help..ben sr
Old 05-27-2013, 08:32 PM   #3
Bad Double Sink Drainage
Thanks Ben Sr.! I have no idea if it's vented, but was worried that the "venting" from the garbage disposal wasn't letting the other sink drain.
I like the 2 p-trap idea!
Double Sink Drain - P-Trap layout?-img_1056.jpg   Double Sink Drain - P-Trap layout?-img_1044.jpg
Old 05-28-2013, 11:42 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 996
Get rid of that mess, double trap is best but not necessary get rid of that flex according crap, come down from the strainer the tee off to the disposal, you'll have to relocate the trap to fall under the strainer side a 45 should do the trick, watch the tubular tee some of them have a baffle if you install it upside down you'll have draining issues,
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 05-29-2013, 06:36 PM   #5
Rewards Points: 1,952
Love to know where you found that accordion pipe coming off the disposal.... I do not remember having that on any disposals I installed. Try cleaning the cross bars in your sink stopper. Single traps never caused a problem for me if sink was vented.
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 06:52 PM
Sink drain leaking, question bergerdude Plumbing 3 03-27-2011 12:43 PM
Condensate draining into sink drain fritzycat1 HVAC 0 01-23-2011 01:39 AM
Reversing P-trap in bathroom sink drain? DK75 Plumbing 3 03-02-2010 01:30 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
