Double Sink Bathroom Rough-in - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-30-2008, 08:57 PM   #1
Double sink bathroom rough-in
We are remodeling our bathroom and have moved the sink causing us to move the drain pipes. I need to run the waste water from one sink past the second sink into the main and the vent. Is it has easy as a T at the second sink and an elbow at the first?
MikeyP is offline   Reply With Quote
Old 09-30-2008, 09:22 PM   #2
Registered User
Termite's Avatar
Hey MikeyP, welcome to DIY Chatroom.
Hard to picture exactly what you're up against. Any chance you can show a picture of the two sinks' locations and the drain/vent? It would make helping you out a lot easier.
Old 09-30-2008, 09:29 PM   #3
Gotta have a p trap between the sinks and the pipe to the drain. Other than that you are good to go as you describe.
Marvin Gardens is offline   Reply With Quote
double sink gurgles! Bcoleman6 Plumbing 4 02-24-2008 09:49 PM
Bathroom Sink Shutoff Valve, Supply Lines, Removing CathrynH Plumbing 9 01-10-2008 12:28 AM
Single Sink To Double Sink 39centstamp Plumbing 4 06-24-2007 10:27 AM
Adding an additional sink in Bathroom tke402 Plumbing 1 04-26-2007 09:14 PM
bathroom tub and sink semi-clogged bobo Plumbing 2 04-19-2007 11:24 AM
