Double Bowl Kitchen Sink Drainage Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-25-2011, 08:41 PM   #16
Ran water for about 20 minutes today in the kitchen drain line. No sign of leaks. Also checked washing machine line for about 5 minutes. I did not test it as long as it is mostly exposed, no leakage.
PeteW is offline   Reply With Quote
Old 09-05-2011, 09:41 AM   #17
Re-plumbed the area beneath the sinks and connected it to the new PVC drain line. Didn't get the sink plumbing right the first time. There were about three obstacles I didn't account for or correct ahead of time. 1st I did not notice that the standard sink basket was striped where the nut for the tail piece connects and I was missing the gasket to seal the connection. I didn't see it when I took it apart and so I didn't know it was missing. So... that leaked. Also, I did not see that the ferrel type gasket used for the tail piece slip joint was chipped. So... that leaked. Finally I had some stress where the trap connected to the wall stub. The angle and stub length distance were the problems here. So... that didn't help the other problems. Corrected all of those things and No leaks!
Hats off to the professional plumbers who get this right the first time. And, thanks again to the plumbers and knowledgeable folks who graciously helped me through this project.
Now maybe I can get this puppy rented.
Pete
Venting a sink pump WillK Plumbing 2 12-26-2010 01:21 PM
smell in basement from non-vented kitchen sink ahgill Plumbing 3 10-11-2010 02:39 PM
What size for kitchen sink? oguevarra Kitchen & Bath Remodeling 1 01-18-2010 11:59 PM
vent stack for kitchen sink Knucklez Plumbing 4 04-02-2008 06:49 PM
Need Help with double bath sink trap after remodel cmontel Plumbing 13 12-03-2006 06:06 PM
