#1 |
donut help
I installed a 3" to 3" donught yesterday so I could transition from my cast iron hub to pvc wye. This morning I noticed a small amount of moisture sitting where the pcv and donut meet. It was a tight fit to get the pvc in the donut and tight going into the CI hub. Any ideas? Im not over concerned because it's such a small amount just curious if anyone has had this happen? I cant see how water would wick up between the rubber donut and pcv pipe (no pressure on the system either).
any ideas of what is going on? Jesse |
| Display Modes | |
| How to prepare toilet drain pipe for toilet flange? | brett.c.brown | Plumbing | 11 | 12-15-2011 08:41 PM |
| Using a pipe hub donut to join 3" PVC to 4" Cast iron pipe. | pazmocars | Plumbing | 1 | 12-24-2010 09:37 PM |
| rubber gasket donut for cast iron sewer pipe to pvc | jbitt | Plumbing | 6 | 04-25-2010 01:29 PM |
| How to cut this drain pipe? | Mechelle | Plumbing | 19 | 08-19-2008 12:44 PM |
| Best way to fix a broken flange? | Tmb9862 | Plumbing | 8 | 11-12-2006 05:09 PM |
