Domestic Water Boiler Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-29-2013, 10:47 AM   #1
domestic water boiler question
I have a 20+yr old boiler for heat and hot water. Don't quite get the relationship between the two. If my thermostat is set to turn off the heat, let's say during the summer, how is the boiler running to heat water for domestic use. Also, is there a different control mechanism I can install to do a better job of keeping the system as efficient as an old system can be. A neighbor mentioned a hydrostat but no clue what that is. Thanks very much.
kentannenbaum is offline   Reply With Quote
Old 04-29-2013, 12:27 PM   #2
Rewards Points: 1,448
There should be a pump (circulator) to run the hot boiler water through the heating system and radiators. When the thermostat is lowered for summer, this should not come on. Stopping the circulation of water is not perfect that way but you can install a shutoff valve in the heating line if you wish.
Meanwhile the boiler must be kept at domestic hot water temperature (a separate control called an aquastat, already installed, usually regulates this). Since boiler water is not sent up into the house where it gives up its heat, the boiler doesn't run that much during the summer.
The best step to improve efficiency is to put a fiber glass insulating blanket around the boiler. This too won't be perfect since some parts of the boiler must remain uncovered and/or accessible.
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 07:03 PM
water softener install/manifold question climbhigh1119 Plumbing 10 03-08-2013 12:36 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 09:35 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
