Does Valve Manufacturer Matter? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-09-2010, 08:44 AM   #1
Just call me Andrew
Rewards Points: 1,020
Does valve manufacturer matter?
Do you guys who are more experienced plumbers have a preferred brand for ball valves? I like Watts, just because I've seen lots of pros use them. Is there any reason to believe that they are better than another brand? Are you pretty safe if you shop for stuff like that at a real plumbing supply house?
What about big box stores?
Thoughts?
Andrew
secutanudu is offline   Reply With Quote
Old 07-09-2010, 09:02 AM   #2
Household Handyman
Rewards Points: 1,408
This would depend on the application of the ball valve. "Watts" is a good brand, so is "Apollo" which i used for years in an industrial setting. The advantage of using a plumbing supply house, to me, would be that you have access to qualified sales people who know their product lines and what the "real" plumbers prefer to use. David
Old 07-09-2010, 09:44 AM   #3
I have used many brands. Always open the valve and look through it. Not all ball valves are "full flow", meaning you will see a reduction in the diameter when you look inside, if it isn't. Watts is what I normally use.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 07-09-2010, 09:48 AM   #4
Just call me Andrew
When you solder ball valves...open or closed? I keep reading conflicting things.
Also, do you take the handle off when soldering?
Thanks!
Andrew
Old 07-09-2010, 10:11 AM   #5
Licensed Master Plumber
Closed if possible, but if your heat control is proper it makes no difference. Overheating can destroy the Delrin seat
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 07-09-2010, 10:55 AM   #6
Just call me Andrew
So basically, as soon as the solder melts, stop heating and run the solder in?
Andrew
Old 07-09-2010, 03:05 PM   #7
I always solder valves in the open position to avoid heat build-up in the valve. Since the seating area is "around" the ball, closing it does not help. I have seen valves that have a warning to "disassemble" the valve before soldering. Since I always look towards the future, I use mostly threaded valves and sweat an adapter onto the piping. No reason to remove the handle.
Old 07-09-2010, 03:14 PM   #8
Just call me Andrew
Is there a proper direction in which to install the valve? Or does the "in" and "out" not matter?
Andrew
Old 07-09-2010, 07:39 PM   #9
If the valve is marked with an IN and OUT on it,that is how you install it. I usually install so that when the valve is ON, the handle is like an arrow, pointing the direction of the flow with the end of the handle being the back end of the arrow.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Cant get the valve off (with picture) clof2001 Plumbing 3 05-10-2010 04:04 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
