Does This Sink Need To Be Glued/fastened To The Vanity? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-17-2013, 05:17 PM   #1
Rewards Points: 1,062
Does this sink need to be glued/fastened to the vanity?
The sink and vanity came with no hardware for attaching/fastening one to the other. Should I put some sort of silicon adhesive bead where the two come into contact?
Does this sink need to be glued/fastened to the vanity?-forumrunner_20130517_171740.jpg
Old 05-17-2013, 07:05 PM   #2
Rewards Points: 582
Attachment 71029
I would use latex caulking to set bowl to vanity not silicone...ben sr ony reason if you have to take it apart you can with no damage to vanity or bowl...
The Following User Says Thank You to ben's plumbing For This Useful Post:
amakarevic (05-17-2013)
Old 05-17-2013, 07:21 PM   #3
Rewards Points: 13,300
I use this to set sinks.
http://phenoseal.com/homepage.aspx
You need an adhesive caulking.
Old 05-17-2013, 07:21 PM   #4
Question
so the same kind that goes along the rear edge of the sink against the wall?
Old 05-17-2013, 07:23 PM   #5
Rewards Points: 582
yesben sr
Adding a Second Sink to Vanity MartyB Plumbing 4 08-17-2012 01:33 AM
My vanity sink is "sweating" Bernie41 Plumbing 32 12-10-2011 06:18 PM
Retrofit bathroom vanity with above counter sink Sushijung General DIY Discussions 10 11-26-2010 02:47 PM
Drain Pipe about 20 Inches to the right of Vanity Sink mark2741 Plumbing 2 12-16-2009 11:32 AM
replacing sink in corian vanity top jaybee General DIY Discussions 2 09-01-2007 03:08 PM
