Does PVC Cement Freeze And Ruin?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-14-2010, 10:34 AM   #1
Rewards Points: 562
Does PVC cement freeze and ruin??
Before I do a critical job here,,whats the real scoop on Oatey PVC cement?? Does it get ruined when it freezes?? It wasnt too cold here,,left in a pickup by mistake,,,only 20 BELOW last week.
Primer not a factor since there is so much alcohol in it is my guess
4just1don is offline   Reply With Quote
Old 01-14-2010, 10:43 AM   #2
Rewards Points: 150
I think so. We bring everything like that in when it gets cold.
user69544 is offline   Reply With Quote
Old 01-14-2010, 02:10 PM   #3
Remodeling Contractor
yes it does.
Old 01-14-2010, 03:07 PM   #4
I think the question should be
If it freezes...is it still OK to use after it thaws out ?
Oh wait...that is the title of the thread
Old 01-14-2010, 03:37 PM   #5
The label states to store and use at temps between 40 and 110 degrees, and not to use if the glue is jellied at all. I have had it go bad in the can, even when stored between the recommended temps. If it is a critical job, I would spend the money and buy a new can. nothing worse than redoing a job.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 01-14-2010, 07:08 PM   #6
Use Rectorseal "Arctic" 616 PVC glue if you're working in a cold area.
Ishmael is offline   Reply With Quote
