Does This Plumbing Repair Mean I Have To Replace The Tile Wall? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-02-2010, 05:14 PM   #1
Rewards Points: 682
Does this plumbing repair mean I have to replace the tile wall?
There is a leak behind the tiles in our shower, some of it is running down the spout, some going inside. There is alot of moisture under the tub behind the wall.
I figure I will have to cut the tiles to see what is going on behind there and fix it. Is it possible to cut out a section of tiles, and then replace them? Or will I have to replace all the tiles in the shower?
darsunt is offline   Reply With Quote
Old 12-02-2010, 07:51 PM   #2
a lot of times i'll use the other side of the wall if possible so that you don't have to tear out the surround in the shower. in my area, it's normally a closet on the other side. normally it'll work if it's not an outside wall, so i'd check it out. i've never had luck saving tiles. normally for me the first one breaks no matter what i do to be gentle
the_man is offline   Reply With Quote
Old 12-02-2010, 07:51 PM   #3
It is possible. Ive seen them do it in the DIY books at home depot. I have never been able to do it, no one I know ever had luck doing it. If its as wet as you are describing the whole wall will probably have to come down anyway.
retro is offline   Reply With Quote
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
water damage remove mold & repair or replace drywall homerepair1 Drywall & Plaster 2 02-22-2009 10:00 AM
Temporary Tile Wall auntd Building & Construction 1 05-10-2008 10:42 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
