Does Pex Pipe Sweat Like Copper? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-24-2011, 05:58 PM   #1
does pex pipe sweat like copper?
Do you need to insulate pex cold water pipes to keep them from sweating??
Arch Hill is offline   Reply With Quote
Old 09-24-2011, 06:25 PM   #2
Plumb or Die!
Not in my experience.
plumber666 is offline   Reply With Quote
Old 09-24-2011, 08:07 PM   #3
Civil Engineer
Rewards Points: 4,854
The term "sweating" is a misnomer. Any pipe carrying cold water will condense moisture on the outside of the pipe if the relative humidity in the room is high enough. Probably for historical reasons, this phenomenom is termed sweating, although clearly the water is not coming from inside the pipe (unless the pipe leaks), so the proper term is condensation.
I live in humid New England, and all of the pipes in my basement (some copper, some PEX) used to condense moisture on the outside. This got old, so I wrapped them all in insulation, problem solved. PEX without insulation is not quite as bad as copper without insulation, since the PEX provides a small amount of insulation, but not enough by itself.
Old 09-24-2011, 09:36 PM   #4
I live in nebraska, and have pex in my dirt crawspace. My main 3/4 cold line sweats like crazy when it gets super humid here. Not to mention the water meter does too. I have the plastic manabloc manifold in my wall behind my fridge, but that never sweats at all. just in my crawlspace
rboutin2 is offline   Reply With Quote
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 09:49 PM
copper pipe vs pex I'm in trouble Plumbing 4 06-27-2010 11:42 PM
12/2 wire in contact with Hot water pipe (copper) - Dangerous? Tryvidy Electrical 6 04-21-2009 07:35 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 10:55 AM
