Does An Offset Toilet Flange Interfere With Outflow ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-01-2008, 03:24 PM   #1
Rewards Points: 1,062
Question
does an offset toilet flange interfere with outflow ?
i may want to move my toilet position by an inch but was wondering if there are downsides to using an offset flange, such as impeded outflow, clogging, and such ?
Old 07-02-2008, 11:12 AM   #2
My personal opinion is that any time you change the direction of flow, you have a chance for a clog to form. If it is necessary, go for it.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 07-02-2008, 11:58 AM   #3
Registered User
Termite's Avatar
I'd agree. If it is necessary to meet code or to fit it in somehow, I'd use one. For pure aesthetics, I'd probably not put one in just to avoid having that extra change in direction at the floor.
Old 07-04-2008, 06:30 AM   #4
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
Yes, all offset flanges will affect the flow somewhat, some drastically. A company named Sioux Chief makes one that I would not hesitate to use on my own home, called a Full Flush, part #889-POM (PVC) or 889-AOM (ABS). It will pass a 3" ball, which is more than almost all toilets, and can be rotated 360 degrees for adjustment. It gives 1 1/2" of offset so you would be 1/2" off the other way unless you can roll it either toward or away from the back wall a little, if so you can get it perfect.
Here's a link: http://www.siouxchief.com/Frm_NS.cfm
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Toilet closet flange kensington Plumbing 5 04-27-2008 08:19 AM
Toilet Flange and Flooring brneilly Remodeling 4 04-20-2008 11:37 AM
Toilet flange floor advice Hobb3s Plumbing 6 04-15-2008 09:41 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
Rusted toilet flange on PVC pipe wyoming777 Plumbing 15 11-09-2007 09:53 PM
