Does This Need Welding? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-21-2008, 03:13 AM   #1
Does this need welding?
I was woken up this morning by Fire Rescue at 3 AM. They got a call about a water main break. Apparently the water hose valve to my townhouse snapped off last night. They had to shut off all the water to my townhouse. Does this look like it needs to be welded or can I replace this myself?
motopsyko32 is offline   Reply With Quote
Old 11-21-2008, 07:45 AM   #2
Registered User
Termite's Avatar
Somebody definately snapped that off for you.
You definately don't need a welder. Copper pipes are soldered, not welded. It is not a difficult operation to do, but it will involve a very specific skill set that you may not have yet...It will also involve probable removal of the fitting that remains in order to get a properly shaped piece to connect the new pipe to. It involves an inexpensive propane torch, flux, solder, cleaning brushes/emery cloth, and of course a little new pipe and fittings. It would be an easy job for a plumber, and a relatively easy job for a DIYer that knows the ins and outs of soldering.
Old 11-21-2008, 08:11 AM   #3
crap!... guess I am calling a plumber. Thanks
Old 11-21-2008, 10:45 AM   #4
heard this is a known issue due to cold weather...?
Old 11-21-2008, 11:06 AM   #5
Copper waterlines can indeed break when frozen. In your case, this was not temperature, but someone that was immature. The bend in the bottom of the pipe left in the silcock proves that this was vandalized. It was hit or maybe even stood on to break this way. It looks like a pretty simple job of removing the pieces of copper in the silcock and the tee and replacing them. Hopefully, a police report was filed.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-21-2008, 11:57 AM   #6
Registered User
Termite's Avatar
Yup, it was broken off by somebody. Freezing didn't do that.
Old 11-21-2008, 03:11 PM   #7
no, unfortunately i didnt file a police report. my bedroom window is right next to the pipe. we didnt hear anything at all and we were up at that time. we heard the water running in the pipes but thought it was our neighbors taking a shower (townhouse).
Old 11-21-2008, 05:26 PM   #8
Rewards Points: 1,910
Maybe it broke from the peeping Tom standing on it??
Old 11-22-2008, 10:28 AM   #9
cant peep anything from there. The window is about six feet to the side of it.
Old 11-22-2008, 04:56 PM   #10
If the damage was caused by freezing, there would only be a crack in the pipe, not broken off.
Old 11-22-2008, 07:40 PM   #11
it wouldn't hurt for you to own a propane torch, and realy there not that expensive, you can remove the broken pipe by simply reheating the joint and letting the solder go back to its liquid state, with a pair of channel locks or needle nose plyers you can pull the unwanted pieces out. Also it does look vandalized but it would be smart to buy some pipe insulation and wrap those pipes that are exposed to the elements.
zosoplumber is offline   Reply With Quote
Old 11-26-2008, 01:00 PM   #12
thanks all. Bought a propane torch for next time
yet another welding question amakarevic Tools 4 02-28-2008 09:38 AM
MIG welding amakarevic Tools 28 02-20-2008 08:56 PM
220V Welding Circut Randell Tarin Electrical 10 02-07-2008 09:39 PM
how to repair metal without welding martin9p2 Building & Construction 3 02-18-2007 10:10 PM
Wiring in new Miller 250DX welding machine Jammer Electrical 2 02-25-2006 03:28 PM
