Does This Look Right? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-06-2013, 12:29 PM   #1
Does this look right?
Getting some renovations and plumbing done around the office. Here are the sinks and urinals for the new bathroom. These to my knowledge are supposed to be floating vanities/counters.
I dont think the plumbing is going where it should. I would imagine the plumbing is supposed to be a little more 'hidden' and think this is not exactly right? Just wanted to get some feedback as to what you guys think?
dooeet is offline   Reply With Quote
Old 09-06-2013, 01:18 PM   #2
Wow, i hope these guys arent liscensed plumber cause if they are they should go back to school.. Where to begin tee on a horizontal not allowed, yes the plumbing should be better concealed the rough on the one sink looks too low and should be tee in the wall not outside the wall also the aav is useless where it is, it should be above flood level rim of the sink but the question to ask is why aren they properly vented. Also the one trap and arm is backpitched so when you use the other sink it will dump into the other trap. You need to start over cause everything is wrong and the work is not professional..good luck
Peppe1019 is offline   Reply With Quote
The Following 2 Users Say Thank You to Peppe1019 For This Useful Post:
dooeet (09-06-2013), Javiles (09-07-2013)
Old 09-06-2013, 01:21 PM   #3
Rewards Points: 12,818
Who's doing this work?
Adding your location to your profile would be a big help with possible code concerns.
First thing I see is the pipes are glued crooked.
Second, not sure how it works where you are but in VA water does not run up hill. That right hand drain is to low.
If the drain had of been higher inside the wall all those lines could have been up higher as well.
This is a case where chrome drains would have at least looked better, or PVC and paint them.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
Old 09-06-2013, 01:21 PM   #4
Dont pay them, fire them and rip everything out that they did and have a pro come in there to do it properly.
The Following User Says Thank You to Peppe1019 For This Useful Post:
Old 09-06-2013, 01:24 PM   #5
747
registered
747's Avatar
Rewards Points: 534
The work is a f-in joke.
747 is offline   Reply With Quote
The Following 3 Users Say Thank You to 747 For This Useful Post:
dooeet (09-06-2013), Javiles (09-07-2013), Peppe1019 (09-06-2013)
Old 09-06-2013, 01:27 PM   #6
Thats what I was thinking. I am not a pro, but to me none of that looked like it is supposed to.
Old 09-06-2013, 01:28 PM   #7
Forgot too mention the water line rough thats how its done too. There should be 6-8" spread and located usually 3" above the rough drain not dangling out of the wall like twizzlers.
dooeet (09-06-2013)
Old 09-06-2013, 02:09 PM   #8
so i should have this all redone and probably have the wall opened up too?
Move the drain and water lines up and have the vent in the wall up to the roof, correct?
Old 09-06-2013, 03:03 PM   #9
Yes open the walls, no you now the height so rough the drains accordingly with a double sanitary or fixture fitting or you can stack tees, for each set of cabinets and conitnue vents through the roof, you can tie the vents in together before exiting. Water lines also should be properly strapped in wall and spread according to standards. Lav drains should be set at 18" off finished floor and water should be 21".
dooeet (09-06-2013)
Old 09-06-2013, 03:18 PM   #10
Plumber
TheEplumber's Avatar
Rewards Points: 348
If this is a public restroom- where's the ADA fixtures?
Sent from my iPhone using DIY Forum. Watch out for spell check
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
Old 09-06-2013, 04:00 PM   #11
Rewards Points: 1,690
Wow I would suggest you fire these clueless hacks. Then get ready to open up the walls because obviously no one from the government has inspected the job.
The Following 3 Users Say Thank You to Ghostmaker For This Useful Post:
DidIDoThat (09-12-2013), dooeet (09-06-2013), Javiles (09-07-2013)
Old 09-06-2013, 04:31 PM   #12
Pardon my lack of knowledge...
What are ADA fixtures?
Old 09-06-2013, 04:47 PM   #13
Plumber
Rewards Points: 348
American Disability Act- for people with disabilities.
Urinals, lavs and toilets are set at special heights for them
Old 09-06-2013, 05:00 PM   #14
Ahhh... gotcha. I am in Canada so a bit different here. But there is a separate Disability access bathroom being built too.
Old 09-06-2013, 05:55 PM   #15
Doesn't Canada have building departments?
