Does Garbage Disposal Lead To Downstream Plumbing Clogs? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-28-2013, 08:39 PM   #1
Rewards Points: 452
does garbage disposal lead to downstream plumbing clogs?
Just wondering with all the crap tenants flush down the garbage disposal, does junk build up in the drain 30ft downstream and result in clogs over time?
my tenants grind pasta and rice in the sink food processor
pman6 is offline   Reply With Quote
Old 12-28-2013, 08:42 PM   #2
Rewards Points: 12,878
Sure can and will.
One of the most useless inventions ever made.
That trash need to go in the trash can not the sink.
Old 12-28-2013, 08:50 PM   #3
Mad Scientist
I always recommend removing disposals from rental housing. Too many maintenance calls.
McSteve is offline   Reply With Quote
The Following 3 Users Say Thank You to McSteve For This Useful Post:
ben's plumbing (12-29-2013), oh'mike (12-28-2013), VIPlumber (12-29-2013)
Old 12-28-2013, 09:19 PM   #4
"my tenants grind pasta and rice in the sink food processor"
There must be something to this, I heard from a few people the drain was really cloged after pasta down the disposal!
Hardway is offline   Reply With Quote
Old 12-28-2013, 09:50 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 354
Two of the worst foods to put down a disposal........unless you're a drain cleaner
Old 12-28-2013, 09:57 PM   #6
Mad Scientist
Pasta, rice, tortillas. Ick.
Old 12-28-2013, 10:40 PM   #7
DIY staff
Rewards Points: 7,174
I've run into two clogs so bad that I just cut out the pipe and replaced it----
I also recommend removing them from rentals---to many calls for coins,broken glass and screws jamming the machines---
Old 12-29-2013, 12:05 PM   #8
Rewards Points: 1,706
A garbage disposal is not meant to be a trash can.
Old 12-29-2013, 12:49 PM   #9
Rewards Points: 582
Originally Posted by joecaption View Post
Sure can and will.
sorry to disagree joe...1 st you are right they can cause clogs...2 nd if used properly and according to manufactures specs ..it will function well...I have had 4-5 in my 3o yrs at same house.....no clogs in kitchen line or main.... but my wife uses it as it is supposed to be used and cleans it on a weekly basis... ben sr
Old 12-29-2013, 08:28 PM   #10
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
I too recommend removing them from rental properties. The trouble is that people dont use them correctly. Like Ben, I've had a disposal since my first home...and that was more years ago than I care to remember. No troubles, but we use it as it is intended to be used.
JDC is offline   Reply With Quote
The Following User Says Thank You to JDC For This Useful Post:
Old 12-29-2013, 08:39 PM   #11
I've found Lobster claws, whole corn cobs, chicken bones.
Anyone with a septic tank should not have one.
In this area it's against code to have one.
Old 12-30-2013, 09:08 AM   #12
Rewards Points: 352
The two tenants of the duplex were sitting on the porch having an animated discussion. What was overheard was "By Gawd I bet my garbage disposal will chew up a frozen chicken"
plumberinlaw is offline   Reply With Quote
Old 12-30-2013, 11:17 AM   #13
Rewards Points: 3,130
Same here. Interestingly, when my "development" was platted in the 1960s, it had a homeowners' association. The C&Rs at the time required every residence to have a disposal though we're all on septic systems. Fortunately, the association was disbanded years ago since, of the 160-odd lots (some as large as 16 acres), only about 40 have ever been built on.
Connecting Garbage Disposal and Switch to Dishwasher Electrical drcjsnider Electrical 23 11-04-2013 08:50 AM
How to wire Dishwasher, Garbage Disposal, and switch... SurfAndSand Electrical 3 08-18-2013 07:51 AM
Wiring garbage disposal switch whodikai Electrical 6 06-08-2013 09:34 PM
Dishwasher/Garbage Disposal + Plumbing AZLambdaK1 Plumbing 5 06-18-2010 12:11 PM
slow draining garbage disposal lchiu7 Plumbing 3 04-05-2009 04:00 PM
