Does Code Require Floor Drain For Water Heater? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-20-2009, 09:35 PM   #1
Does code require floor drain for water heater?
I want to re-locate my water heater into a utility closet and finish the basement. I want to move it 25 feet and put it next to a concrete wall. Does code require a nearby floor drain? Can I put a pan under the water heater and drill a 1" hole thru the basement floor to drain the water from a water heater problem into the 8" of gravel that is suposed to be under the slab?
Quickdraw is offline   Reply With Quote
Old 05-21-2009, 06:29 AM   #2
Rewards Points: 150
you would have to check your local codes. Here in missouri they are not required but I would suggest it to avoid a mess if the heater ever starts leaking or the t and p blows. As far as drilling the slab the key word there is supposedly.
al's sewer is offline   Reply With Quote
Day and Night Heater blink code 31 mlh HVAC 7 01-31-2008 11:57 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
NC code for Breaker amperage rating in new home for Water Heater, Dryer, Range? lynne Electrical 5 08-26-2007 08:44 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
