Old 03-18-2012, 09:24 PM   #1
does cast rust shut?
trying to help my sons house out a bit. remodeling bath room off master bedroom. took ugly pink tile off,,,exposed galvinized drain pipe leaking where screwed into cast iron stack.
now replacing with plastic pipe BUI iron was barely screwed into cast and inside cast part it is completely plugged on both sides. didnt know cast plugged that hard,,chipping with hammer and chisel barely touches it
Does the cast clog that hard or galvinized 1 1/2" cause that? Its a 3" stack with a sink drain out both sides...if I put new walls in with new wall tile I have zero access in case it rusts shut again.
This pipe has more of a tee in it,,,a shoulder in the 1 1/2" tees to rust shut,,,or is the only permanent cure a new plastic stack from basement floor on up???????
4just1don is offline   Reply With Quote
Old 03-18-2012, 09:42 PM   #2
MarginallyQualified
Originally Posted by 4just1don View Post
...exposed galvanized drain pipe leaking where screwed into cast iron stack.
...is the only permanent cure a new plastic stack...
In short, no.
You can't do better than cast (if you know how to work with it).
Replace the damaged fitting/portion as needed.
The Following User Says Thank You to TarheelTerp For This Useful Post:
jaydevries (03-18-2012)
Old 03-18-2012, 09:51 PM   #3
GC/Master Plumber/Mech
If you have the walls open the I would suggest replacing the stack to PVC. I have seen to many time a crack in the stack. While it's open it will be easier.
As far as the hardness build up in the T. Heck yes it gets hard. Build up of scum, scale and other junk, and over the years it gets really tough to get out.
If the stack looks good you may get by simply replacing the trap arms.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-18-2012, 09:52 PM   #4
call me E
TheEplumber's Avatar
Originally Posted by TarheelTerp View Post
In short, no.
I got to agree. Cut out the tee as needed and make repairs. Cast iron is fire rated and quiet. Can't say that for plastic.
Be sure to support the vent stack when cutting
Old 03-18-2012, 09:57 PM   #5
If you do cut out the T and replace it make sure that you support the pipe above the T.
Cast is very heavy and gravity is not kind when that stack comes down.
Old 11-10-2012, 12:41 PM   #6
GoldNotSilver
Our 100 year old house had all cast iron drain and waste pipes. YES, it can rust shut--both the drain AND the vent pipes had considerable corrosion buildup. I'd post pictures, but I don't want to get that close!
Wanting to avoid a complete bathroom remodel, hubby tried to snake the drains several times, but ran into a solid obstruction. He's quite skilled, knows what he's doing.The ENTIRE drain pipe was filled with rusty crud. Not poo, hair, or gook--RUST. A 45% elbow in the vent pipe had substantial flaky rust too.
PVC is noisier, but it doesn't rust through or rust shut. PEX is working well for us too.
Jo Swearingen is offline   Reply With Quote
Rust removal from cast iron tub Jupe Blue General Discussion 4 05-08-2011 10:13 AM
removing rust from a vintage painted cast iron doorstop Margo Painting 6 03-08-2011 04:22 PM
shut off valves on cast iron radiators bdw2677 Plumbing 2 10-21-2008 08:07 PM
remove rust cast iron tub workingirl General Discussion 13 08-23-2008 03:41 PM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 09:20 PM
