Does Anyone Know Where To Get Metric Waste Pipes? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-14-2010, 10:22 AM   #1
Rewards Points: 156
Does anyone know where to get metric waste pipes?
I have european shampoo sinks in a hair salon that take 40mm flexible waste pipes. They typically tear about once a year because the sink basin tilts up and down to accommodate different sized people. The tear occurs where the pipe attaches to the drain stem. Anyway I've traditionally just ordered more of them through the beauty supply shop but I know I can get them cheaper if I could buy in bulk. I can't seem to find a US supplier that carries metric waste pipes. Does anyone know of anybody who stocks them?
The pipe I'm using now is Italian made from SPB. It reads S20P07B620I Autoestinguente UL 94 VO Size 40mm Magnum Air. It's a grey, ribbed tube. Thanks!
jayp is offline   Reply With Quote
Old 07-14-2010, 11:45 AM   #2
Owner
LateralConcepts's Avatar
I would try a supply house that specializes in industrial hose.
Something like this.
http://www.spokanehose.com/
Maybe give them a call. If they don't have it, they may be able to refer you to someone that does.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 07-14-2010, 02:16 PM   #3
i have that flexible pipe on the bath , wash basin , etc its standered over here , but its not that flexable and i think the hot water would make it brittle and crack , you can get a large clear plastic hose reinforced with cord in the middle ( like your garden hose ) 1/8" to 1/4" thick made for hot and cold water
HARRY 65 is offline   Reply With Quote
Old 07-14-2010, 02:25 PM   #4
Rewards Points: 156
thanks
I realize I could get a number of hose types but my problem is that 40mm isn't widely available in the USA. We usually use 1 1/2".
Old 07-14-2010, 03:26 PM   #5
have you ever tried 1 1/2" pipe on it because there is little difference if its to big a jubilee clip ( dont know what you call them ) would make it tight around the pipe , tried to insert image but it would not work
Old 07-14-2010, 03:27 PM   #6
http://www.tooled-up.com/Product.asp?PID=5296
Combining vent pipes in the attic. a4aj Plumbing 5 02-04-2010 12:20 PM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK Remodeling 7 11-04-2009 09:10 AM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 10:03 PM
New Natural Gas pipes being installed frplymstr Plumbing 12 01-05-2009 02:18 PM
Finding waste pipes under a slab Eva Plumbing 15 01-02-2009 03:12 PM
