Does Anyone Know What This Brass End Piece Is? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-10-2012, 11:09 AM   #1
does anyone know what this brass end piece is?
Does any one know what in the world this piece on the end of this hose is? I am a smog shop owner in California and these fitting 'probe tips' cost $30-60 ea! They got to be cheaper to make!
wnsind is offline   Reply With Quote
Old 01-10-2012, 11:42 AM   #2
MarginallyQualified
Rewards Points: 2,464
It is a component in an engineered, tested and approved assembly.
Of course they are cheaper to make than the $30-$60 resale price.
They would have to be.
Old 01-10-2012, 11:45 AM   #3
Rewards Points: 1,578
I'm curious as to why you need new ones; because they wear out or get damaged?
bob22 is offline   Reply With Quote
Old 01-10-2012, 12:05 PM   #4
The guy we buy these from is a parts guy selling them out of his truck bed. He makes them in his garage but won't tell me what the tip is. we have to do a vacuum test every 3 days on these components to ensure they do not leak at all. Its not used in a way that anything can explode or harm anyone. It just sucks the emissions from the tail pipe to the smog machine. That break Left and right.
Old 01-10-2012, 12:08 PM   #5
The 'probe tip' we are using right now is a tip that is poorly made. Where is screws to my sample hose its just a ton of solder to seal the hose to the fitting and the newer one we got last week is crimped on both ends. The guy said ' these are easy, takes me 5 mins' but won't tell me anything about the tip.
Screw holes in vinyl siding piece due to awning removal - fill or replace? mark2741 Building & Construction 9 03-24-2011 12:21 AM
PEX Brass Fittings Turning Inside Tubing After Cinch Clamped GeeJay Plumbing 1 03-01-2011 09:16 AM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 09:23 AM
Carcinogens in brass fittings? cliffspielman Plumbing 7 02-06-2011 01:50 AM
Removing single piece of siding shortagain Remodeling 4 01-02-2006 10:12 AM
