Does 90 Degree Elbow Have Proper Slope? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-25-2014, 09:45 PM   #1
Rewards Points: 236
Question
Does 90 degree elbow have proper slope?
I plan to create an extension to shower drain as depicted on the attached diagram.
Does any one know if a 90 degree elbow is designed to have the correct slope already or I need to do something to create the slope?
Thanks!
325_man is offline   Reply With Quote
Old 03-25-2014, 10:02 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 984
Don't think that's gonna work.. post location so we can match your plumbing code.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 03-25-2014, 10:34 PM   #3
Rewards Points: 236
I am in Prince William County, VA.
Old 03-26-2014, 12:13 AM   #4
Rewards Points: 582
need to have a 2"trap and vent.....
Old 03-26-2014, 10:02 AM   #5
Rewards Points: 236
But, is the slope built in all fixtures?
Old 03-26-2014, 03:34 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 348
the shower is sloped- but fittings are not
Old 03-26-2014, 04:38 PM   #7
Rewards Points: 236
I'm sorry for using the wrong term.
Let me try to rephrase the question.
Are all PVC fittings, i.e. elbows, T's, Y's, etc biult with the appropriate slope? In other words, a 90* elbow is not actually 90*. It is just a bit more than 90* so that if a perfectly straight piece of pipe were inserted into it, it would drop 1/4" per foot.
Thanks!
Old 03-26-2014, 05:03 PM   #8
Plumber
Rewards Points: 348
I'm sorry for using the wrong term. Let me try to rephrase the question. Are all PVC fittings, i.e. elbows, T's, Y's, etc biult with the appropriate slope? In other words, a 90* elbow is not actually 90*. It is just a bit more than 90* so that if a perfectly straight piece of pipe were inserted into it, it would drop 1/4" per foot. Thanks!
no. Not in plastic fittings. You apply the appropriate grade to the pipe while the glue is wet. Then every piece of pipe must be supported- no stress on the fittings
Old 03-26-2014, 05:58 PM   #9
Rewards Points: 582
torpedo levels work great for setting fall on fittings...
Old 03-26-2014, 07:30 PM   #10
Rewards Points: 1,684
Where is your trap? Perhaps you like the great sewer smell?
Old 03-26-2014, 11:19 PM   #11
Rewards Points: 236
There is a trap below the concrete. I have tested it by pouring water into the pipe.
Old 03-27-2014, 06:42 AM   #12
DIY staff
Rewards Points: 7,174
The trap must be directly below the drain--no off sets allowed----
I'll step out and let a plumber explain why----
Old 03-27-2014, 07:12 AM   #13
Rewards Points: 236
Originally Posted by oh'mike
The trap must be directly below the drain--no off sets allowed---- I'll step out and let a plumber explain why----
Is that a code requirement (i.e. No off sets allowed)?
Old 03-27-2014, 07:18 AM   #14
DIY staff
Yes it is----adding a zig zag like that creates an illegal S trap--and also makes rodding the drain almost impossible.
You need to open the floor and move the drain---this is usually a fairly simple task if the existing drains are PVC---
black iron gas line and slope BlueBSH Plumbing 11 11-09-2011 09:58 PM
Need irregular pvc elbow huai Plumbing 8 08-06-2010 12:17 PM
4 inch 90 degree PVC elbow w/2 inch heel inlet amakarevic Plumbing 5 07-27-2007 07:59 PM
LB or Elbow LAR234 Electrical 6 01-05-2007 08:30 AM
45 Degree balcony supports rickr01 Building & Construction 5 09-12-2005 12:10 PM
