Does 10 GPG Hardness Require Softening? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-24-2013, 12:44 PM   #1
Does 10 GPG hardness require softening?
I just bought a new house (with new appliances). The water in the city I live in has a water hardness of 10 gpg. Should I be concerned about this hardness? I drink purified water, so I am mostly concerned about damage to the plumbing/appliances. Is a water softener necessary?
Any advice is appreciated
mdlucero is offline   Reply With Quote
Old 03-24-2013, 12:49 PM   #2
Rewards Points: 12,794
http://www.budgetwater.com/article_hardness_chart.htm
Old 03-24-2013, 06:27 PM   #3
Rewards Points: 3,130
Before we got a softener, our water was about the same level of hardness as yours. Same scenario, new home and all new appliances. Within a couple of months, there was noticeable white film around faucets and inside the dishwasher. Laundry did not come out clean. Glasses were spotted. Had to clean my drip coffee maker weekly or it stopped working. Draw your own conclusion. If you've just moved in, now's the time.
Gallon Per Grain (hardness)?? Mark76 Plumbing 3 12-24-2012 10:37 AM
Final hardness and salt dosage cgarai Plumbing 6 05-15-2012 05:10 PM
does my furnace require 240 volts to start/run? MLMIB HVAC 1 02-05-2011 08:34 AM
Does your job require a permit? housedocs General DIY Discussions 203 12-01-2010 08:28 AM
Exterior Wall Insulation require plastic barrier? BillyDIY Building & Construction 14 03-05-2009 11:19 AM
