Do You Need To Connect The Hot Water Hose To A Washer? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-14-2011, 01:43 PM   #1
Do you need to connect the hot water hose to a washer?
We recently moved in and when trying to hook up the washer, found the spigot/valve thing coming out of the wall leaks/sprays water when turned on.
This is the hot water valve (I think ... hard to tell since they aren't marked and I'd have to let the water run long enough to fill buckets before one would cool off due to poorly insulated pipes and hot sun).
Anyway...we need to do laundry. Except for whites, everything is cold wash...can I just run the washing machine with the cold water connected and the hot water hose not connected or do both hoses have to be pressurized with water for some internal functioning of the machine to work properly?
Machine is a Samsung HE front-loader, two years old.
Boar is offline   Reply With Quote
Old 07-14-2011, 02:11 PM   #2
the Musigician
DangerMouse's Avatar
We've always used ONLY cold water, so yes, you can.
Of course, you need to cap off the hot water inlet hole...... it could get a bit messy otherwise.
DM
Old 07-15-2011, 04:24 PM   #3
DM
I like doing laundry while standing in a pool of soapy suds ... it adds an element of danger to an otherwise mind-numbing task, like I'm the James Bond of the Rinse Cycle.
Thanks for the info and tip.
Old 07-15-2011, 04:31 PM   #4
the Musigician
You're funny.... you fit right in here!
DM
Old 07-15-2011, 09:53 PM   #5
Learning by Doing
Leah Frances's Avatar
My DH's Grandmother (rest in peace) ONLY ever used cold water. The only drawback is that cold water doesn't help much with allergens (unless you bleach - everything).
If you are allergy free.... Go for it!!
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
leak on blue part of washer where you connect your hose Dianah Appliances 3 05-12-2011 12:33 PM
Need to get more water out of my hose bibs.. kooshball Plumbing 2 07-04-2010 08:36 AM
garden hose water spillage: damage to pipes, huge water bill? cluelessDIYer Plumbing 5 06-26-2010 11:42 AM
Simple hose connection? BataviaJim Plumbing 6 03-25-2010 12:52 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
