Do Water Hammer Arrestors Go Bad? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-23-2012, 02:40 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
Do water hammer arrestors go bad?
I noticed when I do laundry I've been getting lot of water hammer. I have an arrestor for the hot and cold and they are maybe 3 years old or so. Do these go bad after a while, or is there some kind of maintenance I should do to them?
I could fasten the pipes better too I guess, but that amount of hammer is probably bad regardless. I'd have to see if I can find a pressure gauge one day and install it. I'd be curious to know what the water pressure is here. I've been told it's around 130PSI. It's considered higher than normal.
Old 09-23-2012, 03:07 PM   #2
Rewards Points: 13,446
That amount of pressure would be about double what it should be.
Fix that and I'd bet the hammer will go away.
Old 09-23-2012, 03:25 PM   #3
Wire Chewer
Rewards Points: 90
I was thinking that too, do I just have to install a regulator?
Old 09-23-2012, 03:29 PM   #4
That will do it.
Make sure it's installed in the main line. There's nothing in the whole house that needs that much pressure.
Old 09-23-2012, 05:50 PM   #5
Question
Re: Do water hammer arrestors go bad?
Is this the kind you have to drain regularly to leave in air?
I don't know if there are any other ones.
Dave Shoff is offline   Reply With Quote
Old 09-23-2012, 05:56 PM   #6
Red,
Do you mean to tell me that you do not have a PRV installed? And anecdotally the pressure is at ~ 130? I'm surprised that you haven't had leaks, ruptured fittings, etc... all over the show. Most fixtures are rated for around 70 psi, so if the above is truly the case then get a PRV, with gauges before and after, installed pronto.
VIPlumber is offline   Reply With Quote
Old 09-23-2012, 06:13 PM   #7
Wire Chewer
Rewards Points: 90
Well I'm estimating on the pressure, I recall someone mentioning that it's around there in my area, I'll have to see if I can find a gauge at the hardware store and install it so I can confirm. For pressure regulators, how do those work, can you actually adjust them to a certain psi rating or are they set? I might also take this opportunity to learn how to solder copper as the main line is copper and I want to keep it that way since it's bonded to the electrical panel further down. Guessing I will want to put my clamp on meter around it to ensure there is no current.
Speaking of leaks, one thing that does leak is the 1/4 pipe for my humidifier. No matter how many times I reinstall that pressure fitting, change the ring, add teflon tape, it always leaks. I need to turn the valve only slightly to prevent it from leaking. So maybe this has to do with the pressure.
Old 09-23-2012, 06:58 PM   #8
Rewards Points: 152
Yep, they're adjustable. I've found these ones to be good (Watts):
Have an integral screen in them that is removable for cleaning. Make sure you take the unions/gaskets off before soldering
burnt03 is offline   Reply With Quote
Old 09-23-2012, 07:08 PM   #9
Wire Chewer
Rewards Points: 90
Cool think that's what I'll get if the hardware store has them, which I'm sure they will as I've seen them before. I'll also install a pressure gauge if I can find one. I have not soldered before but I want to learn. I might practice on something other than the main line first though.
Old 09-23-2012, 07:28 PM   #10
Plumber
TheEplumber's Avatar
Rewards Points: 542
Arrestors usually don't go bad in 3 yrs.
If you have air chambers- yes and you should recharge them.
At 130psi- all bets are off on the arrestors tho. Might be a tad too much pressure for them
Old 09-24-2012, 07:11 AM   #11
Rewards Points: 1,492
Do it yourself water hammer arrestors (vertical stub pipes) are recharged by draining the plumbing system and then turning the water back on.
Arresters you buy and then screw onto the back of the washing machine have bladders or spring loaded devices inside. They are probably not repairable if they go bad.
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
big time water hammer Steelhead Plumbing 2 10-22-2009 08:34 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
