Do U Need P Trap For Bathtub? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-01-2011, 07:48 PM   #1
Rewards Points: 113
do u need p trap for bathtub?
I'm about to put in a new standard size bathtub. I was at home depot today to pick up some drain kit. I was told that I don't need a p trap when I questioned why the kit didn't come with one. Is this true ? thx
oldhouse49 is offline   Reply With Quote
Old 10-01-2011, 07:58 PM   #2
the Musigician
DangerMouse's Avatar
I'm PRETTY sure the apron store employee is wrong.....
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
VIPlumber (10-01-2011)
Old 10-01-2011, 08:15 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 904
Every fixture needs a trap. Never trust a box store
The Following User Says Thank You to TheEplumber For This Useful Post:
DangerMouse (10-01-2011)
Old 10-01-2011, 08:43 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
You have got to be foxing kidding me.
I'd call the store and talk to the manager about that. That's just plain ridiculous, uncalled for, blatantly stupid, against every plumbing code on the planet yet alone the entire universe, I could go on for days idiotic.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
Old 10-01-2011, 09:55 PM   #5
DIY staff
Rewards Points: 7,174
Old 10-01-2011, 11:01 PM   #6
How else are sewer gases going to be kept out of your house?
VIPlumber is offline   Reply With Quote
Old 10-01-2011, 11:35 PM   #7
that is why you dont ask for advice in an apron store. now maybe they said that because you should already have a p-trap under the tub and wouldnt need another one?
Old 10-02-2011, 12:23 AM   #8
Doing it myself
Alan's Avatar
That's possible, but a longshot. However, if anything, in a box store, i'd expect them to try and sell you something you don't need, not the opposite.
Journeyman Plumber
Old 10-02-2011, 04:25 AM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 2,124
Now wait a min.....I think we are beating up on a kid for the wrong reason....
I would be willing to bet that in a majority of cases, you could replace the bath tub...or drain and never have to deal with the p-trap.
Hence, if you replace the bathtub...as long as the drain is in the same place....the p-trap is below it...and unless you know what to look for, most people won't see it.
A good analogy......door bells.....how many people replace their door bell and never realize they have a 24Vac transformer somewhere? The way you guys are talking, if someone replaces their door bell, they have to replace the transformer too.....
Old 10-02-2011, 09:07 AM   #10
Plumber
Rewards Points: 904
All I said was "never trust a box store" That goes for their employees and products too.
Old 10-02-2011, 10:11 AM   #11
Rewards Points: 113
thanks for the info guys.
another question. after I install the sewer lines(ABS) for the tub and toilet, someone will pour concrete on top, what can I use to sleeve/wrap the pipe for protection? thx
Old 10-02-2011, 10:38 AM   #12
Plumber
Rewards Points: 904
I use a couple wraps of "sill seal". Its the foam material that framers use between the concrete and bottom plate.
Put 1 or wraps around the pipes at the concrete level. Fasten with duct tape. On the toilet stub, use enough wraps so its about a 1/2" thick. This will allow room for the flange.
Old 10-02-2011, 10:39 AM   #13
Doing it myself
Alan's Avatar
Around here, they don't like the pipe travelling horizontally embedded in concrete. When we do travel through it (vertically) we use regular sill foam and duct tape.
Journeyman Plumber
Old 10-02-2011, 12:11 PM   #14
Rewards Points: 113
well, the abs pipe will be underneath a new slab in the bathroom. what would you recommend doing? skip the cement where the pipe runs and put plywood on top instead?
Old 10-02-2011, 12:32 PM   #15
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,264
The pipe is supposed to be in the fill under the slab not in the slab. Usually the area where the trap and the vertical riser are located is boxed out and left free of concrete.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
VIPlumber (10-02-2011)
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
Keep cast iron trap or new ABS trap? thebigsee Plumbing 1 01-26-2010 03:18 AM
No drain trap in a 7-year old home - is this normal? curls00 Plumbing 2 12-05-2009 12:40 PM
Cat trap fever radtek General DIY Discussions 13 05-31-2009 06:18 PM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 10:10 AM
