Do They Make A Tee Or Wye That... - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-11-2012, 05:16 PM   #31
Rewards Points: 99
what vents? none of the fixtures in my house are vented anywhere else except for that main stack that they run into. Do you want me to take pics of the pipes under the sinks and behind the shower access panel?
dwcopple is offline   Reply With Quote
Old 04-11-2012, 05:30 PM   #32
Okay, okay , okay. If this "saniplus" is like a Sovent system, doesn't that change everybody's answers? Is this a combo waste/vent stack? I really don't know. I have only seen a sovent a couple of times, never really installed one.
broox is offline   Reply With Quote
Old 04-11-2012, 06:10 PM   #33
The saniplus is nothing like a sovent system.actually it's the opposite.sovent slows the draining water down to prevent breaking trap seal.as far as your venting issue if you don't have any vents on anything else in your house why change.those pipes in the basement are drains dude.ive put in multiple saniflow systems and have allways vented the way I've told you.im done with this thread but my advice is to contact your local building dept and ask them or go buy a how to book cause if you can't understand basic venting I'd hate to see your new bathroom
plumberman134 is offline   Reply With Quote
Old 04-11-2012, 08:03 PM   #34
Plumber
TheEplumber's Avatar
Rewards Points: 566
Originally Posted by dwcopple View Post
I NEED TO VENT MY SANIPLUS SYSTEM ABOVE ALL THE OTHER INLETS FROM FIRST FLOOR DRAINS. I am trying to figure out how I can do that with only 8 3/8" of 3" stack to deal with. That is why I made the drawing as another option of how I can work it. I need to know if my idea will work fine.
This tells me you do not understand or know the basics of venting plumbing fixtures.
As mentioned several times, You need to tie in 6" above the highest fixture flood rim served by those drain lines-- NOT just above "ALL OTHER OUTLETS FROM THE FIRST FLOOR DRAINS"
Quoted from SANIPLUS website--- "All of Saniflo products require an 1-1/2 inch vent pipe, which must be vented to the main vent stack as per plumbing codes. The Sanicompact 48 and Sanistar models do not require a vent connection since they are considered self contained units.
It is not recommended to use an air admittance valve or a mechanical spring-loaded device as they only allow air to flow one way."
Notice it says--"as per plumbing code". You have had several plumbers from across the country telling you that code. Forget what the sales rep told you. It was wrong.
Old 04-11-2012, 09:23 PM   #35
Fair enough, I did not know. Thanks
Old 04-11-2012, 09:32 PM   #36
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Since I didn't see anyone define it yet (and since he doesn't seem to understand what it means) here I go :
Taken from Oregon Residential Plumbing Specialty Code :
206.0
Flood Level Rim : The top edge of a receptor from which water overflows
This includes all fixtures : Toilets, sinks, tubs, showers, lavatories, clotheswasher standpipes, etc etc etc. . . . .
Journeyman Plumber
Old 04-12-2012, 06:19 AM   #37
Rewards Points: 99
that is good then. That top 1.5" line is over 6" from all the other ones. That will be the vent and I will reroute the old line down into the stack below.
Old 04-12-2012, 08:53 AM   #38
Lol!!!!!
Old 04-12-2012, 09:01 AM   #39
Doing it myself
Alan's Avatar
You just don't get it. Hire a professional please.
Journeyman Plumber
Old 04-12-2012, 10:10 AM   #40
Rewards Points: 99
So is the flood rim the top of my highest vanity upstairs then. These terms are senseless
Old 04-12-2012, 05:32 PM   #41
Thread killer
Rewards Points: 272
Quick experiment. Go to a sink on the highest floor of your home. Put a plug in the drain and stick your finger in the overflow hole. Turn on the water. Let the sink fill until until it pours onto the floor. You would have now filled your sink up to and over its flood rim. Measure your stack 6 inches above this height, tie in your venting at that height. Note: the stack may be in a wall at this level
Canucker is offline   Reply With Quote
The Following User Says Thank You to Canucker For This Useful Post:
hammerlane (04-15-2012)
Old 04-12-2012, 07:27 PM   #42
Doing it myself
Alan's Avatar
Thumbs up
Journeyman Plumber
Old 04-12-2012, 11:14 PM   #43
Plumber
Rewards Points: 566
I did that experiment in the boys room when I was about 12 years old. Amazing how paper towels hold back water
Old 04-13-2012, 06:14 AM   #44
Rewards Points: 99
Thanks for the info. I wish you would of used layman's terms from the get go and all of this would've been much easier. I do have a question though. What difference does it make if I cut in 6" above the "flood rim"? I don't understand how if even if there was a flood or back-up that got to that ridiculous of a level of water how could it possible penetrate the sealed PVC and affect a pipe that runs out of my roof. Can anyone explain that???
Old 04-13-2012, 08:41 AM   #45
Plumber
Rewards Points: 566
What do you mean by water penetrating the sealed PVC? The water will already be in the pipe
How do you make a shower base for a oversized shower nateyro Kitchen & Bath Remodeling 4 01-17-2012 09:39 PM
How to make a custom floor transition chuckp27 Flooring 9 12-02-2011 10:48 AM
FREE plans/instructions for easy to make Magic Box! DangerMouse General DIY Discussions 5 07-23-2009 04:14 PM
Want to make cuts in cabinet walls to put in shelfs humberguy Carpentry 3 07-09-2009 09:07 PM
How to make room for humidifier zunk HVAC 3 02-24-2009 05:00 AM
