Old 04-09-2012, 04:32 PM   #1
do they make a tee or wye that...
I need a 3" wye with 1 1/2" inlets 90 degrees from each other NOT 180*. I will take a pic of where I need to add a vent line and need info on how to do it. Thanks in advance!
dwcopple is offline   Reply With Quote
Old 04-09-2012, 04:45 PM   #2
here is where I need to put one. It is 8 3/8" from the top of the current wye to the floorboard.
Old 04-09-2012, 04:46 PM   #3
Old 04-09-2012, 05:49 PM   #4
joed's Avatar
379 different fittings here. I did not look through all of them for the one you asked about.
http://www.lascofittings.com/Default...rdThisPage=371
Do not PM with questions that can be asked in a forum. I will not respond.
Old 04-09-2012, 06:06 PM   #5
Where ate you cutting a vent in?from the looks of that it wouldn't be legal to cut a vent in there as that stack looks like it catches drains on the floors above
plumberman134 is offline   Reply With Quote
The Following User Says Thank You to plumberman134 For This Useful Post:
plummen (04-09-2012)
Old 04-09-2012, 06:17 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Im at a loss for what youre trying to accomplish,get rid of that fernco coupling and install a no hub coupling
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 04-09-2012, 08:04 PM   #7
cut it all out and start over ....its a mess.....
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 04-09-2012, 08:24 PM   #8
I need to add an 1.5" vent line to the top above all the first floor drains for my Saniplus system. The very top fitting pictured would work fine if it had another 1.5" inlet 90* to the front instead of 180* which would place it towards the block wall. How else can I get a vent line in there?
Old 04-09-2012, 08:54 PM   #9
I'm still not understanding but as far as fittings they make every angle you would ever need.Never have I said I can't finish a job because they don't make a fitting to fit my angle,so pick up some wyes and twyes,90s,45s and 22s and I'm sure you'll get what you need
Old 04-09-2012, 09:16 PM   #10
Experienced
Jackofall1's Avatar
The vent line you are adding needs to be higher than the flood plane of the highest appliance. which means you have to be above the flood plane the sink that ties into that stack.
Mark
The Following 3 Users Say Thank You to Jackofall1 For This Useful Post:
ben's plumbing (04-10-2012), plumberman134 (04-09-2012), plummen (04-09-2012)
Old 04-10-2012, 06:52 AM   #11
i am aware of that, that is why i am asking what I should do. You know how they set up double wye's like \I/ Well I would need one with the 1.5" legs 90 degrees apart from each other, not 180*. How can you not understand this???
Old 04-10-2012, 07:22 AM   #12
Experienced
Jackofall1's Avatar
What you need to do to do it right, is tie the vent you are trying to establish above the top of the highest appliance/fixture the stack serves, which puts the vent connection in the wall above the point you are interested in.
Mark
Old 04-10-2012, 12:38 PM   #13
Ok..I got ya now.youll never find a fitting like that cause there's no need for it.Cut in a single 3 by 1.5" wye and off the branch use a 1.5" wye or twye for the extra branch you are looking for
Old 04-10-2012, 02:08 PM   #14
can I just take that top (top most 1.5" in the pic) and cut that back somewhere along that line and have it wye in the lower part of the stack where I will be installing the saniplus discharge? Then use the now open 1.5" spot in the topmost wye as my 1.5" vent?
Old 04-10-2012, 02:16 PM   #15
like this
How do you make a shower base for a oversized shower nateyro Kitchen & Bath Remodeling 4 01-17-2012 10:39 PM
How to make a custom floor transition chuckp27 Flooring 9 12-02-2011 11:48 AM
FREE plans/instructions for easy to make Magic Box! DangerMouse General Discussion 5 07-23-2009 05:14 PM
Want to make cuts in cabinet walls to put in shelfs humberguy Carpentry 3 07-09-2009 10:07 PM
How to make room for humidifier zunk HVAC 3 02-24-2009 06:00 AM
