Do They Make A PVC 4" "T" With A 2" Off The Side? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-21-2009, 05:22 PM   #1
Rewards Points: 266
do they make a PVC 4" "T" with a 2" off the side?
I am in the process of changing out Cast iron to PVC.
The cast iron had a "T" with a cleanout plug but on the side it has a 2" spot where a galvanized drain line was screwed in. the galvanized is shot.. I cant get it out of the cast iron
So the plan is to change the whole thing out. Do they something like this in PVC? what would it be called
4x4x4x2?
thanks
What have I done is offline   Reply With Quote
Old 08-21-2009, 06:22 PM   #2
Master Plumber Lon
Send a message via Yahoo to lonsplumbing
fitting
Supply houses carry all kinds of fittings and every house has different fittings.
lonsplumbing is offline   Reply With Quote
Old 08-21-2009, 07:56 PM   #3
You could use 4" T or a Y and connect the 2" pipe with a 2"X4" reducer also!
Old 08-22-2009, 04:18 AM   #4
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Its called a 4X2 crowsfoot tee around here. You can get them with left or right 2" inlet
JDC is offline   Reply With Quote
Old 08-23-2009, 09:43 AM   #5
Knucklez's Avatar
Rewards Points: 932
yes they make them. i used 3" x 2" x 3" T, but i saw at the store the same thing with 4" x 2" x 4".
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 08-24-2009, 04:37 PM   #6
Rewards Points: 266
i need something like this. I found this at Amazon.com but is only 3" I need/want 4" so 4x4x4 with a 2" inlet. Anyone know of a place online I can find for reasonable? This one on Amazon is only $13.02 which is awesome but it isnt big enough.
thanks again
Not sure if we should use 2" foam on the outside of our house before side it???? notsure??? General DIY Discussions 11 12-07-2009 04:31 AM
Building a big deck, just want to make sure its right f8lyer8s Carpentry 14 05-20-2009 11:01 AM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
What can make a roof slump on one side? clueless88 Roofing/Siding 7 07-17-2008 01:56 PM
Side By side refrigerator Susie Q Appliances 6 08-31-2007 03:26 PM
