Old 03-29-2009, 09:15 PM   #1
Do I need vents?
House doesn't any vents except main vent located on the exterior of the home. Does my sink, shower, and washing machine need there own vents if so if if i route them to the attic can i run through the siding underneath the eves? Any help would be great
jeepdogsfishing is offline   Reply With Quote
Old 03-29-2009, 09:47 PM   #2
GC/Master Plumber/Mech
Do I need vents?
Jeep,
Did you have a pro come out and take a look at the DWV system or have the main rodded like I suggested from your other thread?
Old 03-29-2009, 10:01 PM   #3
Do I need vents?
I have a 1940s house and all of the bathroom plumbing along with the washing machine is vented with a single vent. The kitchen sink has its own. I've been told by plumbers that as long as you have one vent on the line, you're good...meaning if I added anything else, I just need to tie it into one of my existing drains. I don't know if that's the best advice or not but two plumbers told me the same thing.
jayp is offline   Reply With Quote
Old 03-29-2009, 10:06 PM   #4
Do I need vents?
Jeep,
There may not be pipes coming up through the walls they may go vertical in the wall and turn horz and then run to the vent stack. You may not see all the venting going to the attic
Old 03-30-2009, 11:46 AM   #5
Do I need vents?
Whatever you do, run them as high as possible so you don't get the worst whiff of the neighborhood you can imagine.
Removing some vents rdmccaw HVAC 4 10-22-2008 02:00 PM
Big trouble with gable vents! Beth777 Building & Construction 9 08-11-2008 08:32 AM
ridge/soffit vents not enough?? cbice74 Roofing 1 06-16-2008 06:02 PM
sofit vents + gable end vents no ridge vent mattg1970 Roofing 5 10-18-2007 10:47 AM
How many heating vents needed per room? AllGoNoShow HVAC 4 01-23-2007 05:06 PM
