Old 11-18-2012, 12:45 PM   #1
Do I need a vent for my tub?
I'm planning on framing/roughing in the plumbing for my basement bathroom. I wonder if I need to add a vent for my tub. It seems unusual, but I'm not sure. Obviously it would have to be connected before the P-trap under the tub. The home was built less than two years ago.
The dotted line of the plumbing under the slab is my suspicion based on what I can see. If the pipes run as I suspect, the line to the tub would meet the other dotted line after about 5'6".
Do I need a vent for my tub?-plumbing-diagram.jpg   Do I need a vent for my tub?-drain-lines.jpg
TomU is offline   Reply With Quote
Old 11-18-2012, 12:55 PM   #2
JOATMON
ddawg16's Avatar
Yes....you want a vent....but I believe it goes after the p-trap....
One of the experts will along shortly with a nice little pic showing you how to do it....
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 11-18-2012, 01:00 PM   #3
I guess it depends on the perspective. Following the water flow, yes it would be after the p-trap. If that makes sense.
New Roof marknok Roofing 4 08-06-2011 12:41 PM
Water Heater Vent Question pd417 Plumbing 1 05-15-2010 01:34 PM
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 01:09 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 07:34 PM
