Do I Need A Shower Vent - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-25-2008, 07:40 PM   #1
I Want To Install A Corner Shower Will I Also Need A Shower
Vent
WGC454 is offline   Reply With Quote
Old 11-25-2008, 08:02 PM   #2
skyman's Avatar
Lightbulb
Vent
Is there an existing vent, or are you putting this in all new including the drain? You absolutely need a vent, every fixture that has a drain needs a vent. Sorry if you have to do it, but if your connecting this to an existing shower you're taking out, you'll be fine as long as it's not too far away. Really need more information on your problem, but I hope it works. Good luck, and let us know!
skyman is offline   Reply With Quote
Old 11-26-2008, 10:47 AM   #3
Every fixture needs a vent. If not installed, drainage will be affected and the water sealing the trap can be sucked out, allowing sewer gas to enter the home.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
Bubbling in toilet rballard Plumbing 11 08-30-2008 07:15 PM
Low-Slope Ventilation - Cobra Fascia Vent and Cor-a-Vent Roof-2-Wall vent atulc Roofing/Siding 7 08-22-2008 10:40 PM
Plumbing Vent size recommendations rlhed Plumbing 4 07-31-2008 12:01 AM
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 12:09 AM
