Do I Need To Replace My Water Heater? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-02-2013, 11:12 AM   #1
Question
Do I Need to Replace my Water Heater?
I had a sump pump failure on 10/31 that caused 3-4" of water to pool up across the entire finished basement. I immediately called ServiceMaster for the cleanup. They brought in a plumber that said a little of the insulation in the water heater got wet and that the entire unit should probably be replaced. It still works fine, and ServiceMaster said they believe they can dry it out pretty well by turning the pilot light off, pointing an industrial blower into it for 24 hours, and keeping dehumidifiers/fans running close by for 3 days.
Any thoughts on whether or not the water heater should be replaced? It is 8 years old and we've never had an issue with it.
msmcett79 is offline   Reply With Quote
Old 11-02-2013, 11:29 AM   #2
Rewards Points: 13,300
I leave it alone unless this was salt water it should be fine.
The Following 3 Users Say Thank You to joecaption For This Useful Post:
ben's plumbing (11-02-2013), jmon (11-02-2013), plummen (11-02-2013)
Old 11-02-2013, 12:55 PM   #3
joed's Avatar
Rewards Points: 12,026
The heat from the pilot and hot water should help dry it out.
Old 11-02-2013, 01:43 PM   #4
Plumber
Do you have home owners insurance ?
If you do I would let him replace it as part of the damage in the claim.
If not, and its working I would keep it and if it fails later , you got a little extra life out of it.
DidIDoThat is offline   Reply With Quote
Old 11-02-2013, 02:14 PM   #5
Thanks for the replies! Unfortunately, this is not covered by homeowner's insurance. I recently moved out of this house and am now renting it out. I checked with five different companies and nobody offers sewer backup with a Landlord's policy in Illinois. If this happened two months ago under the insurance I had while living there it would have been covered. Frustrating.
Old 11-02-2013, 02:27 PM   #6
FClef's Avatar
Rewards Points: 160
Was the burner gas valve at any time under water? If so, this is unsafe and the valve should be replaced. If, however it was never underwater and just a little of the pilot assembly was, then you should be OK.
If the water heater is old, maybe the plumber is letting you know that it should be replaced.
"Human beings can always be relied upon to assert, with vigor, their God-given right to be stupid"
Dean Koontz - Seize The Night
FClef is offline   Reply With Quote
Old 11-02-2013, 02:40 PM   #7
The gas valve is about 12" off the ground so was never close to the water. Thanks, FC!
Old 11-02-2013, 03:04 PM   #8
Rewards Points: 582
leave it alone ...8yrs old let it live out its life.....ben sr
Tags
water heater insulation , water heater replacement , water heaters
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 11:22 PM
Tankless Water Heater a7ecorsair Plumbing 56 05-04-2012 10:17 AM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 03:35 PM
Water Heater Constantly Failing/Replaced DroidGuard12 HVAC 6 04-11-2012 04:41 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
