Do I Need To Relocate Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-16-2007, 11:24 AM   #1
Rewards Points: 14
Question
Do I need to relocate drain?
Hi all,
I have and existing shower that got moldy and am now redoing it.
It's 3x5 feet and the drain is 17 inches from one end. I've been doing some reading and it seems some suggest the drain to be in the middle of the floor. But from the diagram of my shower, you can see that my showerhead is kind of at the end where the drain is and doesn't really point to the middle of the showerspace, so I'm wondering if mine drain is actually better where it is? Perhaps I don't know all the reasoning behind drain location? Thoughts? It seemed to work OK in the location it's at now...
Parry
sting88 is offline   Reply With Quote
Old 11-16-2007, 11:36 AM   #2
My personal feeling is that as long as it drains properly, the location is your choice. Some may want a "symetrical" look with the drain being centered. I would leave it as is.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-16-2007, 05:35 PM   #3
Send a message via AIM to Marlin
You can have the drain anywhere you want it so long as the shower is properly pitched. It shouldn't really matter and I don't know of any code dictating the location of a drain in a shower. Once you start getting into very large showers you will have some requirements but not in your average household shower.
Marlin is offline   Reply With Quote
Old 11-19-2007, 03:31 PM   #4
Rewards Points: 150
I recently replaced our shower and the drain was not centered. I was restricted by floor joist location. From what I was able to determine as long as the slope is correct for drainage, the location doesn't matter. The off center drain did add a slight increase in tiling difficulty only because it was not symetrical.
steve1234 is offline   Reply With Quote
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 03:15 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 08:59 AM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 03:42 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-22-2006 11:13 PM
