Old 11-10-2012, 11:54 PM   #1
Do I need to protect PEX from concrete mix?
I'm finishing a basement wall with mortar mix, and wonder if I can have the mortar mix touch the pex piping, or if I need to ensure that I don't spill any on it or directly get in contact with it. Should I wrap it in plastic and leave a small space between the pipe (that comes out of the wall) and the concrete wall finish? Sorry if I sound stupid here
Also, if I wash down the wall with TSP (Trisodium phosphate, the real stuff), is this dangerous to PEX piping?
Thanks for any advice
TomU is offline   Reply With Quote
Old 11-11-2012, 12:44 AM   #2
call me E
TheEplumber's Avatar
Any pipe that passes through concrete should be sleeved or wrapped.
As for TSP, I can't say for sure but I'd keep it away just to be safe
Old 11-11-2012, 08:16 AM   #3
Master General ReEngineer
Bondo's Avatar
Ayuh,... Pex is directly bedded into concrete in radiant heating systems,...
Concrete has No effects on Pex tubing... That's Why it's used in radiant systems...
Old 11-11-2012, 09:30 AM   #4
Civil Engineer
PEX stands for cross linked polyethylene, a material which is has little reaction to most chemicals. Certainly if you spill some TSP on the PEX, you should wipe it off with a damp sponge, but I would no worry about it. As for sleeving through concrete, it is not the reaction of the concrete with the PEX that is an issue, more if the concrete shifts after construction it could cut the PEX, since PEX is soft. So it might be a worthwhile plan to install an oversize sacrificial sleeve of metal or plastic to run the PEX through.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
TheEplumber (11-11-2012)
Old 11-11-2012, 10:22 AM   #5
Thanks, I'm just paranoid because the pipe coming out of the wall is before the main shutoff valve, so if it fails I can't even shut off the water myself I guess I'll wrap it, just in case, and leave a small gap between the wall finish and the pipe.
Concrete and Brick Repairs spidercharm Building & Construction 6 08-26-2012 05:15 PM
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 36 08-05-2012 11:43 AM
garden shed on existing concrete pad hartkem Building & Construction 6 10-27-2011 09:46 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
