#1 |
Do I need a pressure/bladder tank
Hey guys- I do a lot of DIY, but leave major plumbing and electrical to the pros.
I am in the process of having my wtaer switch from well to county/public. Tap is in place, plumber just has to connect to the house. Question is: Do I still need the bladder tank if I am coming off the well? |
#2 |
Super Moderator
No---the plumber will bypass the pressure tank---
New members: Adding your location to your profile helps in many ways.--M-- |
#3 |
JOATMON
As long as there is no check valve/anti-siphon valve between your hot water and cold water supply....no.
Common Sense is like Deodorant. Those that need it the most don't use it. My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 |
Doing it myself
Depending on local code, and the construction of the piping at the meter box, you may need an expansion tank on the water heater (or somewhere on the cold system)
Around here they install a check valve at the meter, so when the water heater heats, it builds pressure in the system, and an expansion tank is required to alleviate this problem. You definitely don't need one as large as you had for your well.
Journeyman Plumber |
| The Following 3 Users Say Thank You to Alan For This Useful Post: |
| Display Modes | |
| Installation and support of water heater expansion tanks. | Homerepairguy | Plumbing | 46 | 01-28-2013 06:55 AM |
| questions about plumbing hot water tank | bubbler | Plumbing | 13 | 01-18-2012 07:43 AM |
| Septic tank missing T and badly angled main line? | denemante | Plumbing | 3 | 11-22-2011 10:29 AM |
| Toilet | jpark | Plumbing | 18 | 01-05-2009 08:12 AM |
| Nightmare water tank job | Marvin Gardens | Plumbing | 6 | 11-04-2008 12:09 PM |
