Do I Need Plumbers Putty? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-12-2011, 12:28 AM   #1
Do I need plumbers putty?
I just installed double vessel sinks and they are both leaking. There was a black rubber washer/gasket between the sink and drain assembly at both the top and bottom of the sink. Shouldn't that be water tight? Or am I missing putty somewhere?
DimeBag1976 is offline   Reply With Quote
Old 11-12-2011, 12:30 AM   #2
Sorry, the drain is a pop up drain with over flow. And here are some pics.
Do I need plumbers putty?-forumrunner_20111111_223011.jpg   Do I need plumbers putty?-forumrunner_20111111_223039.jpg
Old 11-12-2011, 06:16 AM   #3
Unusual to see a rubber washer supplied for the top. The top is usually putty, the bottom is paper or fiber washer, rubber washer, nut. The finish on the top of the sink and the underside of the popup vary considerably between types and manufacturers, so putty is the usual sealing component.
Old 11-12-2011, 06:23 AM   #4
DIY staff
Rewards Points: 7,174
Do you have a link to the type of drain set you used? Did you use a riser between the bowl and the counter top--??
I never had one of these leak--you must have something in the wrong order---
Old 11-12-2011, 09:09 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Sounds like you said you have a rubber gasket underneath the popup assembly inside of the sink, and one between the sink and the countertop?
Journeyman Plumber
Old 11-12-2011, 10:08 AM   #6
These are the instructions and box they came in. Funny, it doesn't show the little black rubber washer that is between the top of the sink and the flange of drain assembly. It is quite thin. Now should I just remove said washer and use plumbers putty or should I keep both?
Here's the Drain assembly
Old 11-12-2011, 10:11 AM   #7
Here's the box
Here's the instructions
Old 11-12-2011, 04:40 PM   #8
Tried it without the top washer and used putty instead and everything is working fine. Thanks everyone for your input and help. This is an awesome site thanks to all of you.
Old 11-12-2011, 05:18 PM   #9
DIY staff
That thin washer goes between the counter top and the bowl,I believe---Mike---
Smell from Plumber's Putty peanutxyz Plumbing 4 04-15-2011 04:20 PM
Disposal torque removes plumbers putty cpowersr2 Plumbing 4 01-17-2011 07:46 PM
Replaced Faucet. Now water smells of plumbers putty! emperor_black Plumbing 10 03-04-2010 08:19 PM
Clear Silicone instead of Plumbers Putty jmacx81 Plumbing 2 04-29-2009 06:14 AM
Shouldn't use plumber's putty on acrylic tubs?? jayp Plumbing 1 06-10-2008 10:03 AM
