Old 12-05-2011, 05:52 AM   #1
Do I Need New Supply Lines For New Faucet
I am having someone replace a faucet on a pedestal sink for me. The job is a little complicated so I would rather have someone else do it. The person that I may hire recommended replacing the supply lines. (He has not looked at the job yet). Should I take his advice? Thank you.
Faucetguy is offline   Reply With Quote
Old 12-05-2011, 06:35 AM   #2
Super Moderator
Yes --Replace the lines--if the original has rigid lines the old ones won't fit---
And if they are flexible--they should be changed because they are old---
Old 12-05-2011, 07:12 PM   #3
depends on pipe and age pex is a fairly new product but you are gonna have to replace some because it is a compression fitting so it wont come off unless you cut at the fitting, and the pipe will swell so you wont be able put on a new fitting.
"Pex is a very flexible pipe that replaces copper now we have zurn which is the same idea but not compression just a metal ring"
plumbing is offline   Reply With Quote
Old 12-05-2011, 07:18 PM   #4
Super Moderator
What are you talking about?
Old 12-05-2011, 07:23 PM   #5
agree with mike you lost us some where between supply and pex ring
Faucet with attached water lines. msaeger Plumbing 5 08-15-2011 10:19 PM
Rough-in Height for Kitchen Supply Lines? TipsyMcStagger Plumbing 3 08-01-2010 09:55 AM
Rattling garden faucet supply pipe OneTripper Plumbing 2 06-29-2009 08:58 PM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 06:10 AM
increasing washer supply lines to 3/4" instead of 1/2" amatchin Plumbing 3 04-15-2006 05:23 PM
