Do I Need A License In Order To Fix My Tub (California) - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-17-2006, 03:30 PM   #1
Do I need a license in order to fix my tub (California)
Hello all.
My leaking toilet caused a lot of floor damage in my bathroom. I had to move bath tub in order to replace rotten boards properly.
Now some friends tell me that I need to hire licensed guy to put the same bath tub back. Is this true?
I am in California. I tried to research this over the Internet but couldn't find any information related to my question. Please help.
smalgin is offline   Reply With Quote
Old 07-17-2006, 07:17 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
As the homeowner, you can do your own work on the plumbing without a license, but if you hire out, they need to be licensed.
Ron The Plumber is offline   Reply With Quote
Old 07-18-2006, 12:28 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
Some local jurisdictions require certain work to be completed by licensed professionals only, although as Ron said, in most places a homeowner can repair their own property as long as it is done to code with proper permits (if required).
Check with your Building Inspection Department for local code, permit and inspections requirements before beginning any major work, just to be on the safe side.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-18-2006, 05:11 PM   #4
This is a question for your local city or county Building and Safety department. It is a repair that does not involve retrofitting the plumbing to a degree that it affects the intended performance. Your new Waste and Overflow fittings and how they are attached should be tested for leaks. Fill the entire tub with water and observe your connections form underneath and behind the tub. Drain the tub and observe all connections.
PSZach is offline   Reply With Quote
General contractors license. raymond_anthony Building & Construction 5 08-20-2006 04:07 AM
Contractors license question SUB-ZERO Plumbing 13 07-09-2006 04:25 PM
Exterior Paint Prep Order utdel Painting 2 06-24-2006 01:56 PM
Hello From California cmgith Introductions 3 06-16-2006 11:04 AM
