Do I Need Glue For My Under-mount Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-03-2014, 08:55 AM   #1
Rewards Points: 157
Do I need glue for my under-mount sink
Dear experts,
I need to replace my broken under-mount bathroom sink. The existing one is held under the granite top with metal clamps. But also it is glued to the granite top. Or maybe it is some caulk. My question is whether I need that glue or caulk, as I cannot see what it is for. I don't know why I need waterproofing there, as water would never reach the granite top.
Thanks,
Dmitriy
dpreznik is offline   Reply With Quote
Old 02-03-2014, 08:27 PM   #2
Rewards Points: 1,692
Seal the Sink in Place
For most bathroom undermount sinks, all that is needed to mount the sink to the granite is a silicone adhesive. Squeeze a very thin line around the sink cutout on the underside of the granite. The weight of the sink will compress the adhesive slightly, making it spread out, so a thin line is all that is needed. Lower the sink into place, upside down on the countertop's underside, then lift it straight up again. This will cause the adhesive to pull away in small "strings" from the counter to the sink. The air hitting these strings will make the adhesive bond stronger. Lower the sink back into place and leave it undisturbed for 24 hours to dry.
Using Mounting Clips
The majority of undermount sinks only need adhesive to bond them to a vanity counter, but some large or oversized bathroom sinks will also use mounting clips. This small metal clip fastens on posts to both the sink and the granite top. Epoxy is used to attach the posts to both materials, then the clip is slipped over them and a small nut is fastened down on each post to hold the clip in place. The epoxy will cure hard enough to fasten the clips onto the posts in approximately 10 minutes, but the clips still need a full 24 hours to dry before the counter is mounted into place.
The Following User Says Thank You to Ghostmaker For This Useful Post:
dpreznik (02-04-2014)
Old 02-03-2014, 10:12 PM   #3
Professional
TotalHomeworx's Avatar
Yes, It's silicone. Buy 100% silicone caulking not siliconized latex.
www.totalhomeworx.ca
TotalHomeworx is offline   Reply With Quote
The Following User Says Thank You to TotalHomeworx For This Useful Post:
Old 02-04-2014, 07:22 AM   #4
Rewards Points: 157
Thank you gentlemen,
Though I still don't understand why one needs silicone if there are clamps there. Also, how could weight of the sink compress the adhesive, if the sink is under the granite top, and I cannot turn the top over, as it is already installed. I am just going to replace a broken sink.
Old 02-04-2014, 07:41 AM   #5
Rewards Points: 12,830
How do you think you your going to seal water out between the top and the sink without the silicone?
oh'mike (02-04-2014)
Old 02-04-2014, 07:49 AM   #6
DIY staff
Rewards Points: 7,174
The silicone serves several purposes----it's an adhesive and will keep the sink stable if it gets bumped or a clip fails--
The silicone keeps crud from getting into the gap between the counter top and the bowl--eliminating a place for mold to grow.
Also keeps the cabinet dry--while you may not over fill the sink, it is likely that someone will splash water onto the seam---
Tags
bathroom sink , under-mount
DIY Camera Mount divedaddy03 Tools 0 04-06-2013 02:05 PM
top mount sink wont seat carole2cd Plumbing 2 06-20-2010 01:34 PM
Direct mount sink pump recommendation kornfein Plumbing 0 04-29-2010 12:49 PM
do i have to remove old adhesive glue on wall for new ceramic with glue? Limit54 Tiling, ceramics, marble 2 03-01-2010 11:12 PM
Sink Depth dilemna Yippee Plumbing 9 01-01-2008 01:25 PM
